ArcGIS.Core.CIM Namespace / CIMTinNodeValueRenderer Class
Properties Methods Events
    CIMTinNodeValueRenderer Class Members
    The following tables list the members exposed by CIMTinNodeValueRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets an attribute field name. (Inherited from ArcGIS.Core.CIM.CIMTerrainAttributeRenderer)
    Public Property Gets or sets the color ramp. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets the color ramp name. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets embedded data sources. (Inherited from ArcGIS.Core.CIM.CIMTerrainAttributeRenderer)
    Public Property Gets or sets the unique value groups. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets the heading. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets a value indicating whether or not to illuminate. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the label. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets the lookup styleset. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets the maximum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no maximum scale and the renderer will draw at any scale above the minimum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the minimum scale for renderer draw (set as the denominator of the scale's representative fraction). Values less than or equal to 0 indicate there is no minimum scale and the renderer will draw at any scale below the maximum. (Inherited from ArcGIS.Core.CIM.CIMTinRenderer)
    Public Property Gets or sets the symbol. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Public Property Gets or sets a value indicating whether or not to use the default symbol. (Inherited from ArcGIS.Core.CIM.CIMTinUniqueValueRenderer)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTinNodeValueRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTinNodeValueRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTinNodeValueRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
