ArcGIS.Core.CIM Namespace / NAServiceAreaSolver Class
    NAServiceAreaSolver Class Properties
    For a list of all members of this type, see NAServiceAreaSolver members.
    Public Properties
     NameDescription
    Public Property Gets and sets the accumulate attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the applied travel mode. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the applied travel mode as JSON. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the attribute parameters values. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean which indicates if a traversal result is created.
    Public Property Gets and sets the date-time synchronize usage setting.
    Public Property Gets and sets the default breaks.
    Public Property Gets and sets a collection of network source names to NOT use when generating polygons.
    Public Property Gets and sets the name of the hierarchy attribute to be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the hierarchy level count. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the maximum value of the hierarchy attribute. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the number of lower level junctions to explore before searching the next hierarchy level. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean which indicates whether or not to ignore invalid locations. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the impedance attribute name. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean which indicates if the lines will have SourceID, SourceOID, from and to position information added.
    Public Property Gets and sets a boolean which indicates if similar ranges should be merged in the result polygons.
    Public Property Gets and sets the associated network build hash. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the output geometry precision. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the output geometry precision units. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the type of line(s) generated.
    Public Property Gets and sets the type of polygon(s) generated.
    Public Property Gets and sets a boolean which indicates if lines should overlap from multiple facilities.
    Public Property Gets and sets a boolean which indicates if the polygons for all facilities should not overlap.
    Public Property Gets and sets a boolean which indicates if the hierarchy ranges will be reset to the network dataset's hierarchy settings when the solver is bound. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the restriction attribute names. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a setting which indicates how U-Turns should be restricted in the analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets the associated solver overrides. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Public Property Gets and sets a boolean which indicates if lines should be split at breaks.
    Public Property Gets and sets a boolean which indicates if polygons should be split at break values.
    Public Property Gets and sets the date-time value used in time-aware solvers.
    Public Property Gets and sets a boolean indicating whether TimeOfDay is in UTC.
    Public Property Gets and sets the usage type for the TimeOfDay property.
    Public Property Gets and sets the travel direction.
    Public Property Gets and sets a boolean which indicates if the outermost polygon (at the maximum break value) will be trimmed.
    Public Property Gets and sets the distance to trim if polygons are being trimmed.
    Public Property Gets and sets the distance to trim distance units.
    Public Property Gets and sets a boolean which indicates if the hierarchy attribute for the network should be used in analysis. (Inherited from ArcGIS.Core.CIM.NASolverDefinition)
    Top
