ArcGIS.Core.CIM Namespace / CIMCruisingAltitudeDiagram Class
Properties Methods Events
    CIMCruisingAltitudeDiagram Class Members
    The following tables list the members exposed by CIMCruisingAltitudeDiagram.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the text symbol used for the altitude values on the diagram.
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether to auto resize the text.
    Public Property Gets or sets the line symbol used for the arrow that leads from the starting bearing to the ending bearing for a part of the diagram.
    Public Property Gets or sets the text symbol used for the bearing values for each part of the diagram.
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the diameter of the cruising altitude diagram in page units.
    Public Property Gets or sets the text for the diagram title.
    Public Property Gets or sets the diagram type which should be created.
    Public Property Gets or sets the page units used to determine the diameter of the cruising altitude diagram.
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the text for the bottom of the horizontal diagram.
    Public Property Gets or sets the text for the top of the horizontal diagram.
    Public Property Gets or sets the line symbol used for the outline of the circle sections on the diagram.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the text for the bottom left of the quadrantal diagram.
    Public Property Gets or sets the text for the bottom right of the quadrantal diagram.
    Public Property Gets or sets the text for the top left of the quadrantal diagram.
    Public Property Gets or sets the text for the top right of the quadrantal diagram.
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the text symbol used for the diagram title, which appears above the element.
    Public Property Gets or sets the text for the left side of the vertical diagram.
    Public Property Gets or sets the text for the right side of the vertical diagram.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMCruisingAltitudeDiagram.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMCruisingAltitudeDiagram with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMCruisingAltitudeDiagram and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
