ArcGIS.Core.CIM Namespace / CIMBasicRowTemplate Class
Properties Methods Events
    CIMBasicRowTemplate Class Members
    The following tables list the members exposed by CIMBasicRowTemplate.
    Public Properties
     NameDescription
    Public Property Gets or sets the default tool GUID. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the default values.
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the excluded tool GUIDs. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the hidden fields.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the template relationships.
    Public Property Gets or sets the required fields.
    Public Property Gets or sets the tags. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Public Property Gets or sets the per-tool options. (Inherited from ArcGIS.Core.CIM.CIMEditingTemplate)
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Allows a construction tool on the template.
    Public Extension Method Excludes a construction tool from the template.
    Public Extension Method Gets the default construction tool.
    Public Extension Method Gets the excluded construction tools on the template.
    Public Extension Method Read the Tags from a CIMEditingTemplate.
    Public Extension Method Sets the default construction tool.
    Public Extension Method Sets the excluded construction tools on the template.
    Public Extension Method Write an array of tags to a CIMEditingTemplate.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
