ArcGIS.Core.CIM Namespace / CIMNetworkTravelModeDefinition Class
Properties Methods Events
    CIMNetworkTravelModeDefinition Class Members
    The following tables list the members exposed by CIMNetworkTravelModeDefinition.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the array of network attribute parameter definition values.
    Public Property Gets or sets the description.
    Public Property Gets or sets the distance attribute name.
    Public Property Gets or sets the impedance attribute name.
    Public Property Gets or sets the mode type.
    Public Property Gets or sets the name.
    Public Property Gets or sets the output geometry precision units.
    Public Property Gets or sets the output geometry precision value.
    Public Property Gets or sets the array of restriction attribute names.
    Public Property Gets or sets the time attribute name.
    Public Property Gets or sets a value indicating whether to use hierarchy.
    Public Property Gets or sets a value indicating whether to use output geometry precision.
    Public Property Gets or sets the u-turn at junctions policy for traversal between stops.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMNetworkTravelModeDefinition.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMNetworkTravelModeDefinition with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMNetworkTravelModeDefinition and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
