ArcGIS.Core.CIM Namespace / CIMServiceSubLayer Class
    CIMServiceSubLayer Class Properties
    For a list of all members of this type, see CIMServiceSubLayer members.
    Public Properties
     NameDescription
    Public Property Gets or sets the definition expression.
    Public Property Gets or sets the Name of definition expression.
    Public Property Gets or sets the definition filter choices.
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets a value indicating whether or not draw time cumulatively.
    Public Property Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets floor-aware properties if the sublayer is used in floor filtering.
    Public Property Gets or sets the layer definition for dynamic service layer. This is a JSON string in REST API syntax.
    Public Property Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets the pop-up info.
    Public Property Gets or sets the primary symbol renderer.
    Public Property Gets or sets a value indicating whether or not to scale symbols.
    Public Property Gets or sets a value indicating whether the layer is selectable.
    Public Property Gets or sets the URI of the selection set for the layer.
    Public Property Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets a value indicating whether or not to show labels.
    Public Property Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets a value indicating whether or not to show pop-ups.
    Public Property Gets or sets the source ID.
    Public Property Gets or sets the unique identifier for this sublayer within its layer. Set by the system and typically a number. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Public Property Gets or sets the time offset.
    Public Property Gets or sets the time offset units.
    Public Property Gets or sets the transparency of the sublayer as a percentage.
    Public Property Gets or sets the URI of the backing layer. Used when feature layer capabilities are enabled.
    Public Property Gets or sets a value indicating whether or not to use time.
    Public Property Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMSubLayerBase)
    Top
