Forecast Using Time Series Model (GeoAI Tools)
Summary
Predicts the values of each location of a space-time cube using a deep learning-based time series forecasting model that has been trained using the Train Time Series Forecasting Model tool.
Usage
  • You must install the proper deep learning framework for Python in ArcGIS Pro.
    Learn how to install deep learning frameworks for ArcGIS
  • The input is an Esri model definition file (.emd) or a deep learning package file (.dlpk), which can be created using the Train Time Series Forecasting Model tool.
  • This tool accepts netCDF data created by the Create Space Time Cube By Aggregating Points, Create Space Time Cube From Defined Locations, Create Space Time Cube from Multidimensional Raster Layer, and Subset Space Time Cube tools.
  • This tool uses deep learning-based time series forecasting models. Deep learning models have a high capacity to learn and are appropriate for time series that follow complex trends and are difficult to model with simple mathematical functions. However, they require a larger volume of training data to learn such complex trends and use more computational resources for training and inference. A GPU is recommended for using this tool.
  • The Outlier Option parameter can be used to detect statistically significant outliers in the time series values at each location.
    Learn more about detecting time series outliers
  • This tool supports the use of third-party time series models created using the model extensibility feature. The model extensibility feature enables time series forecast tasks using a custom deep learning model file (.dlpk) that is not created using the Train Time Series Forecasting Model tool.
    Learn more about using third-party time series models with ArcGIS.
  • To run this tool using a GPU, set the Processor Type environment to GPU. If you have more than one GPU, specify the GPU ID environment instead.
  • This tool uses a single global forecast model that has been trained on time series data from each location.
  • The Output Features parameter value will be added to the Contents pane with rendering based on the best saved model forecasted time step.
  • This tool creates geoprocessing messages and pop-up charts that you can use to understand and visualize the forecast results. The messages contain information about the structure of the space-time cube and summary statistics of the root mean square error values. Click a feature using the Explore navigation tool to display a line chart in the Pop-up pane showing the values of the space-time cube and fitted values and forecasted values for that location
  • For information about requirements for running this tool and issues you may encounter, see Deep Learning frequently asked questions.
Parameters
Label Explanation Data type
Input Time Series Data
The netCDF cube containing the variable that will be used to forecast to future time steps. This file must have an .nc file extension and must have been created using the Create Space Time Cube By Aggregating Points, Create Space Time Cube From Defined Locations, or Create Space Time Cube From Multidimensional Raster Layer tool.
File
Model Definition
The trained deep learning model file (.dlpk or .emd) that will be used to make the predictions. The model can be trained using the Train Time Series Forecasting Model tool.
The .dlpk file can also be a third-party time series model.
Caution:
A third-party time series model .dlpk file can potentially contain harmful code. Only use these models if you trust their source.
File
Output Features
The output feature class of all locations in the space-time cube with forecasted values stored as fields. The layer displays the forecast for the final time step and contains pop-up charts showing the time series and forecasts for each location.
When using a third-party time series model, the model arguments will be updated according to the parameters specified in the .dlpk file. To learn more about defining model arguments, see the getParameterInfo section in Use third-party time series models with ArcGIS.
Feature Class
Number of Time Steps to Forecast
A positive integer specifying the number of time steps that will be used to forecast the analysis variable. The default value is 2. This value cannot be larger than 50 percent of the total time steps in the input space-time cube for one-step forecasting, and it cannot be larger than 50 percent of the Sequence Length parameter value in the Train Time Series Forecasting Model tool for multistep forecasting.
Long
Match Explanatory Variables
(Optional)
The mapping of field names from the prediction set to the training set. Use this parameter if the field names of the training and prediction sets are different. The values are the field names in the prediction dataset that match the field names in the input time series data.
Value table columns:
  • Prediction—The field names in the prediction dataset.
  • Training—The field names in the input time series data.
Value Table
Output Cube
(Optional)
An output space-time cube (.nc file) containing the values of the input space-time cube with the forecasted time steps appended. Use the Visualize Space Time Cube in 3D tool to see all of the observed and forecasted values simultaneously.
File
Outlier Option
(Optional)
Specifies whether statistically significant time series outliers will be identified.
  • None—Outliers will not be identified. This is the default.
  • Identify outliers—Outliers will be identified using the Generalized ESD test.
String
Level of Confidence
(Optional)
Specifies the confidence level that will be used for the test for time series outliers.
  • 90%—The confidence level for the test will be 90 percent. This is the default.
  • 95%—The confidence level for the test will be 95 percent.
  • 99%—The confidence level for the test will be 99 percent.
String
Maximum Number of Outliers
The maximum number of time steps that can be declared outliers for each location. The default value corresponds to 5 percent (rounded down) of the number of time steps of the input space-time cube (a value of at least 1 will always be used). The value cannot exceed 20 percent of the number of time steps.
Long
Analysis Variable
The numeric variable in the dataset that will be forecasted to future time steps.
String
Model Arguments
(Optional)
Additional arguments that will be used by the third-party model while performing forecasting. The supported model arguments include sequence_length and batch_size. The parameter is only applicable for forecasting using a third-party model.
When using a third-party time series model, the model arguments will be updated according to the parameters specified in the .dlpk file. To learn more about defining model arguments, see getParameterInfo section in Use third-party time series models with ArcGIS.
  • Name—The name of the function argument.
  • Value—The value of the function argument.
Value Table
Environments
Output Coordinate System, Geographic Transformations, Processor Type, GPU ID
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
