Optimal Region Connections (Spatial Analyst Tools)
Summary
Calculates the optimal connectivity network between two or more input regions.
Learn more about connecting regions with the optimal network
Usage
  • The input regions can be either raster or feature data.
  • In a raster, a region is a group of cells with the same value that are contiguous to one another (adjacent). When your input regions are identified by a raster, if any zones (cells with the same value) are composed of multiple regions, first run the Region Group tool as a preprocessing step to assign unique values to each region. Then use the resulting raster as the input regions to the Optimal Region Connections tool.
  • When input regions are identified by polygon, line, or point data, they are converted to raster using the feature ID to ensure that the resulting regions have unique values. Multipart polygons cannot be used as input. When multipoint data is entered, Optimal Region Connections randomly selects one of the points at the location as the region value.
    You can control the resolution of the rasterized input feature regions with the Cell Size environment. By default, the resolution will be set to the resolution of the input cost raster if one is provided.
  • When using polygon feature data for the input region data, care must be taken with how the output cell size is handled when it is coarse, relative to the detail present in the input. The internal rasterization process uses the same default Cell assignment type method as the Polygon to Raster tool, which is Cell center. This means that data that is not located at the center of the cell will not be included in the intermediate rasterized region and will not be represented in the distance calculations. For example, if your regions are a series of small polygons, such as building footprints that are small relative to the output cell size, only a few of them may fall under the centers of the output raster cells, seemingly causing most of the others to be lost in the analysis.
    To avoid this situation, as an intermediate step, rasterize the input features directly with the Polygon to Raster tool, set a Priority field value, and use the resulting output as input to the Optimal Region Connections tool. Alternatively, select a small enough cell size to capture the appropriate amount of detail from the input features.
  • When the region input is a feature, the ObjectID field will be used as the region identifiers.
  • If the input regions are raster and the range of the row IDs is very large (even if there are only a few regions), the performance of the Optimal Region Connections tool may be negatively impacted.
  • Locations identified by the Input Raster or Feature Barriers parameter, cell locations with NoData in the Input Cost Raster parameter, or locations that are not within the Mask all act as barriers.
  • The analysis Mask environment can be set to a feature or a raster dataset. If the mask is a feature, it will be converted to a raster. The cells that have a value define the locations that are within the mask area. NoData cells define the locations that are outside the mask area and will be treated as a barrier.
  • The default processing extent is the same as that of the Input Cost Raster value if one is provided; otherwise, it will be set to the extent of the input regions.
  • Cost raster values that are negative or zero are invalid but will be treated as small positive values. The accumulative cost algorithm is a multiplicative process, and it cannot calculate accumulative cost correctly if cost values are negative or zero.
    If the cost raster contains those values, and those locations represent areas that are to be excluded from the analysis, turn those cells into NoData before running the tool. You can do this using the Set Null tool.
    The NoData value is treated as a barrier in this analysis, so any locations that are NoData in the input will be NoData in the result.
  • For the Output Neighboring Connection Lines parameter, if a cost surface is not specified, the neighbors are identified by Euclidean distance. In which case, a region's closest neighbor is the one that is closest in distance. However, when a cost surface is provided, the neighbors are identified by cost distance making a region's closest neighbor the cheapest one to travel to. A cost allocation operation is performed to identify which regions are neighbors to one another.
  • The optimal output network is created from the paths produced in the optional neighboring connections output. The paths in the optional neighboring connections output are converted to graph theory. The regions are the vertices, the paths are the edges, and the accumulative distances or costs are the weights for the edges. The minimum spanning tree is calculated from the graph representation of the paths to determine the optimal path network necessary to travel between the regions.
  • Each optimal path first reaches the outer boundary of the polygon or multicell region. From the perimeter of the region, the tool continues the paths with additional line segments, allowing for points of entry and exit between regions, and movement within them. There is no additional distance or cost of movement along these line segments.
  • Depending on the configuration of the input regions and their allocation neighbors, a path can pass through an intermediate region to reach a neighboring region. That path will incur costs as it moves through that intermediate region.
  • The optional neighboring connections output can be used as an alternative network to the minimum spanning tree network. This output connects each region to its neighboring cost regions, producing a more complex network with many paths. The feature class can be used as is or as the base from which to create your own network. To do that, select the specific paths you want within the network using the Select By Attributes button, the Select group on the Map tab, or the Select Layer By Attributes tool. Selection of the paths can be based on knowledge of the area and the statistics associated with the paths in the resulting attribute table.
  • This tool supports parallel processing. If your computer has multiple processors or processors with multiple cores, better performance may be achieved, particularly on larger datasets. See the Parallel processing with Spatial Analyst help topic for details on this capability and how to configure it.
    When using parallel processing, temporary data will be written to manage the data chunks being processed. The default temp folder location will be on your local C: drive. You can control the location of this folder by setting up a system environment variable named TempFolders and specifying the path to a folder to use (for example, E:\RasterCache). If you have administrative privileges on your machine, you can also use a registry key (for example, [HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Raster]).
    By default, this tool will use 50 percent of the available cores. If the input data is smaller than 5,000 by 5,000 cells in size, fewer cores may be used. You can control the number of cores the tool uses with the Parallel processing factor environment.
  • The resulting network, from either the minimum spanning tree or the optional neighboring connections, can be converted to a Network Analyst network for additional network analysis.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input Raster or Feature Regions
The input regions to be connected by the optimal network.
Regions can be defined by either a raster or a feature dataset.
If the region input is a raster, the regions are defined by groups of contiguous (adjacent) cells of the same value. Each region must be uniquely numbered. The cells that are not part of any region must be NoData. The raster type must be integer, and the values can be either positive or negative.
If the region input is a feature dataset, it can be polygons, polylines, or points. Polygon feature regions cannot be composed of multipart polygons.
Raster Layer; Feature Layer
Output Optimal Connection Lines
The output polyline feature class of the optimal network of paths that connect each of the input regions.
Each path (or line) is uniquely numbered and additional fields in the attribute table store specific information about the path. Those additional fields are the following:
  • PATHID—The unique identifier for the path
  • PATHCOST—The total accumulative distance or cost for the path
  • REGION1—The first region the path connects
  • REGION2—The other region the path connects
This information provides insight into the paths in the network.
Since each path is represented by a unique line, there will be multiple lines in locations where paths travel the same route.
Feature Class
(Optional)
The dataset that defines the barriers.
The barriers can be defined by an integer or a floating-point raster, or by a point, line, or polygon feature.
Input Cost Raster
(Optional)
A raster defining the impedance or cost to move planimetrically through each cell.
The value at each cell location represents the cost-per-unit distance for moving through the cell. Each cell location value is multiplied by the cell resolution while also compensating for diagonal movement to obtain the total cost of passing through the cell.
The values of the cost raster can be integer or floating point. Cost raster values that are negative or zero are invalid but will be treated as small positive cost values.
Raster Layer
(Optional)
The output polyline feature class identifying all paths from each region to each of its closest or cost neighbors.
This information provides insight into the paths in the network and is useful when deciding which paths should be removed if necessary.
Feature Class
Distance Method
(Optional)
Specifies whether the distance will be calculated using a planar (flat earth) or a geodesic (ellipsoid) method.
  • Planar—The distance calculation will be performed on a projected flat plane using a 2D Cartesian coordinate system. This is the default.
  • Geodesic—The distance calculation will be performed on the ellipsoid. Regardless of input or output projection, the results will not change.
String
Connections Within Regions
(Optional)
Specifies whether the paths will continue and connect within the input regions.
  • Generate connections—Paths will continue within the input regions to connect all paths that enter a region.
  • No connections—Paths will stop at the edges of the input regions and will not continue or connect within them.
String
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Default Output Z Value, Extent, Geographic Transformations, Mask, M Resolution, M Tolerance, Output CONFIG Keyword, Output Coordinate System, Output has M values, Output has Z values, Output M Domain, Output XY Domain, Output Z Domain, Parallel Processing Factor, Scratch Workspace, Snap Raster, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Requires Spatial Analyst
  • Standard: Requires Spatial Analyst
  • Advanced: Requires Spatial Analyst
