Create Spatial Component Explanatory Variables (Spatial Statistics Tools)
Summary
Creates a set of spatial component fields that best describe the spatial patterns of one or more numeric fields and serve as useful explanatory variables in a prediction or regression model.
The input fields should be the explanatory and dependent variables that will be used in a prediction model. The resulting spatial component fields (called Moran eigenvectors) can be used as explanatory variables (in addition to the original explanatory variables) that will often improve the predictive power of the model by accounting for spatial patterns of the other variables.
Learn more about Moran eigenvectors
Illustration
Create Spatial Component Explanatory Variables tool illustration
Usage
  • The tool creates spatial components that can most accurately predict the values of the input fields. Each component represents a spatial pattern, and the selected components will be those whose patterns most closely resemble the patterns of the input fields. For example, if a field has a broad west-to-east trend but also contains small clusters of low and high values, the pattern could be represented by combining two components: one representing the west-to-east trend and the other representing the clusters. By including explanatory variables that resemble the spatial patterns of the explanatory and dependent variables, spatial effects are accounted for in prediction and regression tools such as Generalized Linear Regression and Forest-based and Boosted Classification and Regression. By accounting for spatial effects, these nonspatial prediction models will usually predict more accurately, and spatial bias (such as spatial patterns in the residuals) will often be reduced. This is important so that certain areas are not systematically underpredicted or overpredicted by the model. In addition, coefficients of the explanatory variables can be more easily interpreted because they will estimate the direct relationship between the explanatory variable and the dependent variable while filtering out the noise introduced by spatial effects.
  • This tool is intended to create explanatory variables that can be used in prediction models; however, the Filter Spatial Autocorrelation From Field tool can also be used for this purpose by removing the spatial autocorrelation from the residual or standardized residual field of a prediction model. The spatial components that effectively filter residual autocorrelation are frequently useful explanatory variables and can often provide equivalent model improvement to this tool using fewer components as explanatory variables. It is recommended that you try both tools and compare the results of including the spatial components from each one in the original prediction model (for example, by comparing the adjusted R-squared or AIC values).
  • The spatial components will be returned as fields in the output feature class, and when the tool is run in an active map, the output feature layer will draw based on the first spatial component. The input fields will also be included in the output feature class so that the original explanatory variables and the spatial component explanatory variables can be used to predict the dependent variable in prediction tools without needing to merge the input and output feature classes.
  • The geoprocessing messages include the following tables that summarize the selection of spatial components used to spatially filter the input field:
    • Neighborhood Search History—For each of the spatial weight matrices (SWMs) that were tested, details of the SWM (such as the number of neighbors and weighting scheme), the p-value and adjusted R-squared value when using all components, the adjusted R-squared value when using only the selected components, and the number of components that were selected are displayed. The SWM with the highest adjusted R-squared value using the selected components will be used to create the components and will be indicated with bold text and an asterisk.
    • Spatial Component Search History—For the selected SWM, the ID value of each component (for example, ID 4 means that it was the fourth spatial component), the Moran's I value and p-value of the component, and the adjusted R-squared value of the component (including all previously selected components) are displayed. The rows are ordered by the components that individually predicted the input fields most effectively (highest R-squared value).
  • To select the SWM that will be used to create the spatial components, the tool generates a list of candidate SWMs and tests which one creates spatial components that most accurately predict the values of the input fields. If no SWM files are provided in the Input Spatial Weights Matrix Files parameter, 28 SWMs will be created and included in the candidate list (see Understanding Moran eigenvectors for descriptions of each SWM). If any input SWMs are provided, you can use the Compare Only Input Spatial Weight Matrices parameter to specify whether the candidate list only includes the provided SWMs or includes the provided SWMs and the 28 SWMs created by the tool. For example, to use a single specified SWM, provide the SWM in the Input Spatial Weights Matrix Files parameter and leave the Compare Only Input Spatial Weight Matrices parameter checked.
  • The tool selects among the candidate SWMs using the following procedure:
    1. For each of the 28 candidate SWMs, the SWM is tested for statistical significance by predicting the input fields using all spatial components as explanatory variables. The significance test uses the combined R-squared from all input fields and performs a Šidák correction to the p-value to account for the number of SWMs tested. Any SWM that is not statistically significant will be removed from the candidate list.
    2. For each remaining candidate SWM, spatial components are sequentially added as explanatory variables until either the next component is not statistically significant alone (the p-value is greater than 0.05) or the adjusted R-squared value of the component (and all previously selected components) exceeds the adjusted R-squared value when using all components of the SWM. Each new component is selected by finding the one with the highest statistical significance (lowest p-value) when used to predict the input fields.
    3. The SWM with the largest resulting adjusted R-squared value is selected as the final SWM, and the associated set of selected spatial components are returned as fields in the output feature class.
    This procedure is called the FWD (Forward) selection method and is fully described in the following reference:
    • Blanchet, F. Guillaume, Pierre Legendre, and Daniel Borcard. 2008. "Forward selection of explanatory variables." Ecology 89, no. 9: 2623-2632. https://doi.org/10.1890/07-0986.1.
Parameters
Label Explanation Data type
Input Features
The input features containing fields of the explanatory and dependent variables that will be used in a prediction model.
Feature Layer
Input Fields
The input fields of the explanatory and dependent variables that will be used in a prediction model.
Field
Output Features
The output features that will contain fields of the spatial components that can be used as additional explanatory variables in a prediction model.
Feature Class
Append All Fields From Input Features
(Optional)
Specifies whether all fields will be copied from the input features to the output feature class.
  • Checked—All fields from the input features will be copied to the output feature class. This is the default.
  • Unchecked—Only the input fields will be copied to the output feature class.
Boolean
(Optional)
A list of input SWM files (.swm) that will be used as candidates for the SWM that will be used to create the spatial component explanatory variables. If no files are provided, the tool will test 28 different neighborhoods.
File
Output Spatial Weights Matrix File
(Optional)
The output SWM file (.swm) of the neighbors and weights selected by the tool. This parameter does not apply if you provide an input .swm file.
File
Unique ID Field
(Optional)
The unique ID field of the output .swm file. The field must be an integer and must have a unique value for each input feature.
Field
(Optional)
Specifies whether only the .swm files provided in the Input Spatial Weights Matrix Files parameter will be tested or whether 28 additional neighborhoods will also be tested. The tool will use the SWM that creates spatial components that most accurately predict the values of the input fields. This parameter only applies if at least one input SWM is provided.
  • Checked—Only the input .swm files provided in the in_swm parameter will be tested. This is the default.
  • Unchecked—The input .swm files provided in the in_swm parameter and an additional 28 neighborhoods will be tested.
Boolean
Environments
Geographic Transformations, Output Coordinate System, Parallel Processing Factor, Random number generator
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
