ArcGIS Data Store utility reference
Utilities installed with ArcGIS Data Store provide the ArcGIS Data Store administrator with tools to manage the data store types that are provided through ArcGIS Data Store. This page describes the utilities and provides syntax and examples for each.
All utilities must be run on the machine where ArcGIS Data Store is installed. You can find the utilities in the <ArcGIS Data Store installation directory>/datastore/tools directory.
All utilities must be run on the machine where ArcGIS Data Store is installed. You can find the utilities in the <ArcGIS Data Store installation directory>\datastore\tools directory.
Type the utility name followed by --help to get syntax assistance at the command prompt.
Your login must be a member of the Windows Administrator group, and you must open the Command Prompt with the Run as Administrator option to use the ArcGIS Data Store utilities.
Quick links
Use the following links to access each utility's syntax and examples. Those without links are deprecated, as noted.
