Add a grid
Five types of grids can be added to a map frame in a layout: graticule, measured grid, MGRS grid, reference grid, and custom grid. You can also combine grid types to display multiple coordinate systems on a map. For example, you can display a Universal Transverse Mercator (UTM) measured grid and a graticule on the same map frame, each symbolized differently.
Graticules, measured, MGRS, and reference grids are all added by selecting a grid from a gallery. By default, the gallery is populated with basic graticules, measured, MGRS, and reference grids. If your project contains a style with grids, those grids will also be available in the gallery. Custom grids, however, are based on a polygon or line layer in the map frame and are added differently than other grid types.
Add graticules, measured, MGRS, or reference grids
To add a graticule, measured, MGRS, or reference grid to a map frame, complete the following steps:
In an active layout view, select the map frame in the Contents pane.
On the Insert tab, in the Map Frames group, click Grid
.Select a grid from the gallery.
The grid is added to the map frame.
Optionally, customize the grid by right-clicking it in the Contents pane and choosing Properties.
The Element pane appears containing the grid properties, which you can update.
Repeat these steps to add other grids and graticules.
Since reference grids must have equal-area divisions, they are available for rectangular map frames only.
Add a custom grid
To add a custom grid, complete the following steps:
.Choose New Custom Grid
.A custom grid is added to the map frame.
Select the custom grid in the Contents pane, right-click, and choose Properties.
In the Element pane, from the Layer drop-down list, choose the layer in the map frame on which to base the grid.
The layer must intersect the edges of the map frame because the intersecting features create the grid labels. If the layer does not intersect the edge adjust the map frame extent until it does.
Switch to the Components tab
in the Element pane.Select the Labels component.
Choose the field grid that labels will be based on from the Field drop-down list. Optionally, use the Expression button
to write an Arcade expression for labeling.
