| Name | Description | |
![]() | CIMReportSection Constructor |
The following tables list the members exposed by CIMReportSection.
![]() | Anchor | Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | AutoGrowTextElements | Gets or sets a value indicating whether the height of Text elements in sections will grow based on their content. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | AutoSize | Gets or sets a value indicating whether the section height will grow and shrink to fit the content of the section. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | CustomProperties | Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | DataSource | Gets or sets the data source for a report. |
![]() | ElementFieldProperties | Gets or sets the field properties that will be applied to the elements. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | Elements | Gets or sets a collection of elements. (Inherited from ArcGIS.Core.CIM.CIMGroupElement) |
![]() | ExcludePageNumberPages | Gets or sets the comma delimited list of pages to exclude the page number from. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | ExcludeSectionPages | Gets or sets the comma delimited list of pages to exclude the section from. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | Expanded | Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Expressions | Gets or sets the expressions used by the report. |
![]() | Frame | Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement) |
![]() | GraphicFrame | Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement) |
![]() | HonorColumns | Gets or sets a value indicating whether the section should be displayed in columns. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | KeepSubsectionTogether | Gets or sets a value indicating whether to prevent a page break for a subsection. This property can be applied to the report footer, group header, and group footer subsections. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | Locked | Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | LockedAspectRatio | Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Name | Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Rotation | Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | RotationCenter | Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | StartOnNewPage | Gets or sets a value indicating whether the section should start on a new page. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement) |
![]() | Visible | Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Clone | Creates a deep copy of CIMReportSection. |
![]() ![]() | FromJson | Reconstructs the CIMReportSection with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMReportSection and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
