ArcGIS.Core.CIM Namespace / CIMTableFrame Class
Properties Methods Events
    CIMTableFrame Class Members
    The following tables list the members exposed by CIMTableFrame.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the alternate 1 row background count. Show even row background for this many rows before alternating.
    Public Property Gets or sets the second alternating data record background symbol.
    Public Property Gets or sets the alternate 2 row background count. Show odd row background for this many rows before alternating.
    Public Property Gets or sets the first alternating data record background symbol.
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether to balance the columns of the table.
    Public Property Gets or sets the column border symbol.
    Public Property Gets or sets the gap between table columns.
    Public Property Gets or sets the number of columns.
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the custom where clause. Show rows that match custom where clause when FillingStrategy is set to esriCIMTableFrameFillingStrategy_CustomWhereClause.
    Public Property Gets or sets the default table frame field used when creating new table frames.
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the gap between fields.
    Public Property Gets or sets the fields displayed by the table frame.
    Public Property Gets or sets the strategy used to query records.
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the field name/alias background symbol.
    Public Property Gets or sets the field name/alias border symbol.
    Public Property Gets or sets the gap between field names and rows.
    Public Property Gets or sets the field name/alias underline symbol.
    Public Property Gets or sets the horizontal gap around field values.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the map frame associated with the map surround. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the layer or standalone table that defines the data to display.
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the limit when reducing font sizes. Values is in points.
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the border symbol for row sections: data records, summary statistics, and statistics totals.
    Public Property Gets or sets the gap between rows.
    Public Property Gets or sets the maximum number of rows the table frame will show. 0 Indicates "no limit".
    Public Property Gets or sets a value indicating whether to show the headings.
    Public Property Gets or sets the vertical gap around field values.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMTableFrame.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMTableFrame with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMTableFrame and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
