| Name | Description | |
![]() | CIMMeterReferenceGuide Constructor |
The following tables list the members exposed by CIMMeterReferenceGuide.
![]() | Anchor | Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | AutoUpdate | Gets or sets a value indicating whether properties of the surround should update automatically based on changes in the map. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround) |
![]() | CustomProperties | Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | DrawToSpecification | Gets or sets a value indicating whether to draw the element to specification size or allow user to manually resize element. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround) |
![]() | Expanded | Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Frame | Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement) |
![]() | GraphicFrame | Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement) |
![]() | GridSquareType | Gets or sets the type of the 100,000-Square identification area. |
![]() | IsSingleGridZone | Gets or sets a value indicating whether the grid zone is using single (true) or multiple (false) designators. |
![]() | LineSymbol | Gets or sets the symbol used for the grid lines in the meter reference guide. |
![]() | Locked | Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | LockedAspectRatio | Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | MapFrame | Gets or sets the map frame associated with the map surround. (Inherited from ArcGIS.Core.CIM.CIMMapSurround) |
![]() | MapIndexLayerURI | Gets or sets the layer used to define the area of interest for calculating intersecting MGRS values. |
![]() | MaxScale | Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround) |
![]() | MinScale | Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround) |
![]() | Name | Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | ProductSpecification | Gets or sets the map product specification type of the surround. (Inherited from ArcGIS.Core.CIM.CIMMapProductSurround) |
![]() | Properties | Gets or sets the display properties of the meter reference guide. |
![]() | Rotation | Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | RotationCenter | Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | TextSymbol | Gets or sets the symbol used for the text elements in the meter reference guide. |
![]() | Visible | Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement) |
![]() | Clone | Creates a deep copy of CIMMeterReferenceGuide. |
![]() ![]() | FromJson | Reconstructs the CIMMeterReferenceGuide with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMMeterReferenceGuide and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
