ArcGIS.Core.CIM Namespace / CIMImageMosaicSubLayer Class
    CIMImageMosaicSubLayer Class Properties
    For a list of all members of this type, see CIMImageMosaicSubLayer members.
    Public Properties
     NameDescription
    Public Property Gets or sets the active custom colorizer. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the name of the active range. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets a multidimensional display definition describing the current display slice. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the active variables. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets a value indicating whether layer can be draped on integrated mesh. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the raster table definition. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the attribution text that appears on a map that draws this layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to automatically compute the statistics histogram. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the auxiliary raster properties. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the blending mode for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets identifier the layer's charts. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the raster colorizer. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the compression as a string. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the compression quality. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the custom colorizers. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the custom properties of the layer. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the data connection for the raster this layer is based on. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the display cache type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to draw footprints. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets a value indicating whether to enable any type of effects on the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether this layer is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the feature table. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the footprint draw mode. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the footprint symbol. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets a value indicating whether or not to ignore the rendering rule on identify. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the 3D layer properties. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer effects for the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer elevation. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the URIs of the layers used as masks. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer's scale visibility options. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the layer template. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the map layer type. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the maximum display cache age. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the maximum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the minimum scale for layer draw (set as the denominator of the scale's representative fraction). (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the mosaic rule. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the mosaic sublayer type.
    Public Property Gets or sets a multidimensional extent definition describing the data cube(s) used for analysis. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the page definition which allows for using current map series page to filter features. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the pop-up info. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the range definitions. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets a value indicating whether layer should be rasterized when exporting. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the units for the amount of time to wait between refreshing the layer. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the rendering rule. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets a value indicating whether or not this layer should be included in the search. This property is honored only by layers that support search. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not the layer is selectable. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the selection color. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets the selection symbol. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets identifier that will be used to identify the layer in server. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to show legends. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not the value of the display field or expression is shown when hovering over a layer in the view. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not to show pop-ups. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the time definition. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the time dimension fields. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the time display definition. (Inherited from ArcGIS.Core.CIM.CIMRasterLayer)
    Public Property Gets or sets the transparency of the layer as a percentage. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not to use the selection symbol. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets a value indicating whether or not to use the service cache. (Inherited from ArcGIS.Core.CIM.CIMImageServiceLayer)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether or not to use a fixed time extent for layer visibility. When true, the map time must overlap this extent for the layer to be visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets a value indicating whether or not this layer is visible. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets the fixed time extent for layer visibility. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Public Property Gets or sets an identifier that will be used to identify the layer in a web map. This value is present if the layer originated in a web map and facilitates matching the layer back to its origin when updating the web map. (Inherited from ArcGIS.Core.CIM.CIMBaseLayer)
    Top
