ArcGIS.Core.CIM Namespace / CIMLASStretchInput Class
Properties Methods Events
    CIMLASStretchInput Class Members
    The following tables list the members exposed by CIMLASStretchInput.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the gamma value.
    Public Property Gets or sets a value indicating whether to invert the stretch.
    Public Property Gets or sets the lookup values.
    Public Property Gets or sets the maximum percent.
    Public Property Gets or sets the minimum percent.
    Public Property Gets or sets the number format.
    Public Property Gets or sets the standard deviation parameter.
    Public Property Gets or sets the LAS stats type.
    Public Property Gets or sets the LAS stretch attribute.
    Public Property Gets or sets the stretch classes.
    Public Property Gets or sets the stretch max.
    Public Property Gets or sets the stretch min.
    Public Property Gets or sets the stretch statistics.
    Public Property Gets or sets the stretch type.
    Public Property Gets or sets a value indicating whether to use custom stretch minimum maximum.
    Public Property Gets or sets a value indicating whether to use gamma stretch.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLASStretchInput.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLASStretchInput with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLASStretchInput and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
