ArcGIS.Core.CIM Namespace / CIMGZDLabelGridLine Class
Properties Methods Events
    CIMGZDLabelGridLine Class Members
    The following tables list the members exposed by CIMGZDLabelGridLine.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the dynamic string used to represent the GZD label of the map grid.
    Public Property Gets or sets the type of the graticule element. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the properties of the tick that is at the start of the grid line it represents. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the orientation of the gridLine with reference to the coordinate system of the spatial reference. For graticules it is latitudes and longitudes. For grids it is eastings and northings. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the horizontal position of the GZD label at the center of each UTM grid zone.
    Public Property Gets or sets the horizontal position of the GZD label at the left of each UTM grid zone.
    Public Property Gets or sets the horizontal position of the GZD label at the right of each UTM grid zone.
    Public Property Gets or sets the properties of the interior ticks for a grid line. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets name of the grid line. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the pattern of the grid lines. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets symbol of the grid line. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the properties of the tick that is at the end of the grid line it represents. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Public Property Gets or sets the vertical position of the GZD label at the bottom of each UTM grid zone.
    Public Property Gets or sets the vertical position of the GZD label at the center of each UTM grid zone.
    Public Property Gets or sets the vertical position of the GZD label at the top of each UTM grid zone.
    Public Property Gets or sets the visibility of the corner labels to edges by index. (Inherited from ArcGIS.Core.CIM.CIMGridLine)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGZDLabelGridLine.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGZDLabelGridLine with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGZDLabelGridLine and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
