ArcGIS.Core.CIM Namespace / CIMRasterUniqueValueColorizer Class
Properties Methods Events
    CIMRasterUniqueValueColorizer Class Members
    The following tables list the members exposed by CIMRasterUniqueValueColorizer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the default color.
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the field name to render.
    Public Property Gets or sets the unique value groups.
    Public Property Gets or sets a value indicating whether the default color visibility is shown in the contents pane.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the number format applied to values for display.
    Public Property Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets a value indicating whether the class visibility is shown in the contents pane.
    Public Property Gets or sets a value indicating whether or not to use the default color.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterUniqueValueColorizer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterUniqueValueColorizer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterUniqueValueColorizer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
