ArcGIS.Core.CIM Namespace / CIMRasterVectorFieldColorizer Class
Properties Methods Events
    CIMRasterVectorFieldColorizer Class Members
    The following tables list the members exposed by CIMRasterVectorFieldColorizer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the class breaks.
    Public Property Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the direction band index.
    Public Property Gets or sets the flow representation type.
    Public Property Gets or sets the from unit.
    Public Property Gets or sets a value indicating whether flow is composed from U and V components.
    Public Property Gets or sets the magnitude band index.
    Public Property Gets or sets the maximum magnitude.
    Public Property Gets or sets the maximum symbol size.
    Public Property Gets or sets the minimum class break.
    Public Property Gets or sets the minimum magnitude.
    Public Property Gets or sets the minimum symbol size.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the number format used for format values for display.
    Public Property Gets or sets the reference system for symbol rotation.
    Public Property Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets symbol.
    Public Property Gets or sets the symbolization type.
    Public Property Gets or sets the symbol tile size.
    Public Property Gets or sets the symbol tile size units.
    Public Property Gets or sets the to unit.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterVectorFieldColorizer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterVectorFieldColorizer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterVectorFieldColorizer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
