ArcGIS.Core.CIM Namespace / CIMClassBreaksRenderer Class
    CIMClassBreaksRenderer Class Properties
    For a list of all members of this type, see CIMClassBreaksRenderer members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the additional authoring information used by the renderer. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the background symbol used for graduated symbols. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the barrier weight used for graduated symbols to avoid labels. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the class breaks. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the class break type. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the classification method. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the color ramp. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default description. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default label. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the custom patch for the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the patch shape for the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to draw graduated symbols for polygon features above all layers. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the exclusion clause.
    Public Property Gets or sets the exclusion description.
    Public Property Gets or sets the exclusion label.
    Public Property Gets or sets the exclusion symbol.
    Public Property Gets or sets the custom patch for the exclusion symbol.
    Public Property Gets or sets the patch shape for the exclusion symbol.
    Public Property Gets or sets the field for rendering. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the heading. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the minimum break. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the minimum label. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the normalization field.
    Public Property Gets or sets the normalization total.
    Public Property Gets or sets the normalization type.
    Public Property Gets or sets the number format. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the property that controls how the color ramp is applied to polygon symbols. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the maximum number of records to sample. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to show class gaps. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to use the default symbol. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets a value indicating whether or not to use the exclusion symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. When both Fields and ValueExpressionInfo are present ValueExpressionInfo is used. (Inherited from ArcGIS.Core.CIM.CIMClassBreaksRendererBase)
    Public Property Gets or sets the visual variables.
    Top
