Get started with Knowledge Studio
ArcGIS Knowledge Studio is a web app for working with knowledge graphs. The app provides entity-centric tools to visualize, analyze, compile, and share data. Knowledge Studio is included with the ArcGIS Knowledge Server license.
Knowledge Studio allows you to work with knowledge graphs on the web. A knowledge graph allows you to construct a model that simulates a real-world system. To learn more about knowledge graphs, see What is ArcGIS Knowledge.
You need access to a knowledge graph in your portal to use Knowledge Studio. You can create a knowledge graph using ArcGIS Pro, ArcGIS REST API, or ArcGIS API for Python. If you are working with a user-managed knowledge graph service and you make schema changes such as adding or removing an entity type, you must sync the data model before using that service in a Knowledge Studio project.
Knowledge Studio projects
In Knowledge Studio, your work is organized in projects. A Knowledge Studio project is a workspace for exploring and analyzing knowledge graph data. Each Knowledge Studio project references a knowledge graph and contains a knowledge graph view, a query view, and a dashboard view. The project may also reference related maps, link charts, and data cards.
Opening Knowledge Studio from the app launcher in your portal opens the Knowledge Studio landing page, where you can create a Knowledge Studio project or open an existing project. You can return to the landing page at any time by clicking the Knowledge Studio button Knowledge Studio at the top of the app.
To learn more about Knowledge Studio projects, see Work with Knowledge Studio projects.
Knowledge Studio user interface
Creating or opening a Knowledge Studio project opens the main workspace. From here, you can explore the knowledge graph; create maps, link charts, and data cards; search the project; query the data in the knowledge graph; and configure a project dashboard. There are six key areas in the main workspace, which are shown in the following image and described in the table below. The numbers in the image correspond to the descriptions below.
Workspace diagram
Element
Element 1 Title bar
The title bar displays the title of the project and provides access to Global Search and Documentation .
Element 2 Main menu
  • Knowledge Graph —A quick link to the Knowledge Graph view.
  • Query —A quick link to the Query view.
  • Dashboard —A quick link to the Dashboard view.
  • Project Contents —A list of all the content items in the project.
  • View Contents —A list of the contents of the current view, such as the layers in a map.
  • Query Assistant —An AI assistant to create and run queries in the Query view. Currently a Beta feature.
  • Load Data —Open the Load Data view to convert tabular data from a csv or feature layer into entities and relationships in the knowledge graph.
  • Save —Save the project.
Element 3 Pane list
This area displays panes opened using the main menu buttons. It includes the Project Contents pane and the View Contents pane. The View Contents pane updates based on the type of content item that is open.
Element 4 Content list
Each open content item appears as a tab in this area. The number of tabs you can have open depends on the number of maps or link charts in each content item. If you reach the tab limit, you need to close a tab before you can open a new content item.
Element 5 Main view
The main view of the active content item.
Element 6 Context toolbar
The context toolbar includes tools for the active content item.
