Hydrology geoprocessing functions
Available with Spatial Analyst license.
The Hydrology geoprocessing functions are used to model the flow of water across a surface. They can be applied individually or used in sequence to create a stream network or delineate watersheds.
Information about the shape of the earth's surface is useful for many fields, such as regional planning, agriculture, and forestry. These fields require an understanding of how water flows across an area and how changes in that area may affect that flow.
When modeling the flow of water, you may want to know where the water came from and where it is going. The following topics explain how to use the hydrologic analysis geoprocessing functions to help model the movement of water across a surface, the concepts and key terms regarding drainage systems and surface processes, how the functions can be used to extract hydrologic information from a digital elevation model (DEM), and sample hydrologic analysis applications.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing Function |
Description |
Modifies the cell values of an input surface raster at specified locations. |
Adjusts the stream feature input to match the resolution of an input raster. |
Creates a raster delineating all drainage basins. |
Generates a raster of accumulated flow into each cell from an input surface raster with no prior sink or depression filling required. |
Generates stream line features from an input surface raster with no prior sink or depression filling required. |
Generates a stream raster from an input surface raster with no prior sink or depression filling required. |
Fills sinks in a surface raster to remove small imperfections in the data. |
Creates a raster of accumulated flow into each cell. A weight factor can be applied. |
Creates a raster of flow direction from each cell to its downslope neighbor, or neighbors, using the D8, Multiple Flow Direction (MFD), or D-Infinity (DINF) method. |
Computes, for each cell, the horizontal or vertical component of downslope distance, following the flow paths, to cells on a stream into which they flow. In case of multiple flow paths, minimum, weighted mean, or maximum flow distance can be computed. |
Calculates the upstream or downstream distance, or weighted distance, along the flow path for each cell. |
Creates a line that breaches the local impediment of water flow. |
Creates a raster of flow direction from each cell to its downslope neighbor, or neighbors, using a geodesic method. |
Locates areas that are topographically lower than the surrounding terrain based on spatial characteristics. |
Creates a raster identifying all sinks or areas of internal drainage. |
Snaps pour points to the cell of highest flow accumulation within a specified distance. |
Creates a table and a chart of elevations and corresponding storage capacities for an input surface raster. The tool calculates the surface area and total volume of the underlying region at a series of elevation increments. |
Assigns unique values to sections of a raster linear network between intersections. |
Assigns a numeric order to segments of a raster representing branches of a linear network. |
Converts a raster representing a linear network to features representing the linear network. |
Identifies cells resulting in flow loops on an input flow direction raster. |
Determines the contributing area above a set of cells in a raster. |
