Create classification grid geometry format
Available with Standard or Advanced license.
You can enhance an IPS positioning dataset by adding geometry in the classification grid format. The classification grid represents a uniform grid of square cells covering valid level features. Each cell of the grid is classified as a walkable area, a non-walkable area, an outdoor transition, or an obstacle based on the IPS area, obstacle, and exit or entrance features.
To generate an IPS positioning dataset with the classification grid geometry format, complete the following steps:
  1. Start ArcGIS Pro.
  2. Open the map you created for IPS enablement.
  3. On the ribbon, click the Analysis tab and click Tools.
    The Geoprocessing pane appears.
  4. In the Geoprocessing pane, click Toolboxes.
  5. Expand Indoor Positioning Tools and click Add Geometry To Indoor Positioning Dataset.
    The Add Geometry To Indoor Positioning Dataset tool opens in the Geoprocessing pane.
  6. Click the Target IPS Positioning Datasets drop-down arrow, or click Browse, and choose the IPS Positioning Datasets feature class that contains the dataset you want to enhance.
  7. Click the Target IPS Positioning Dataset Name parameter drop-down arrow and choose an available dataset you want to enhance.
  8. Click the Geometry Format drop-down arrow and choose Classification Grid.
  9. Click the Level Features drop-down arrow, or click Browse, and choose the Levels feature class.
    Use the same Levels feature class that you used to generate the IPS positioning dataset.
    The feature class corresponds to the Levels feature class in the ArcGIS Indoors Information Model and represents the extent of individual floors in the facility. If you do not have data that conforms to the Indoors model, you can create the Levels feature class with the Create IPS Data Model tool.
  10. Click the IPS Area Features drop-down arrow, or click Browse, and choose the IPS Area polygon feature class that represents the areas covered by the fingerprint points of the specified dataset.
    Learn more about creating IPS area features.
  11. Click the Obstacle Features drop-down arrow, or click Browse, and choose a polyline feature class that represents physical barriers that block user movement within a facility.
    Ensure that the selected obstacle features layer includes a LEVEL_ID field. A layer that conforms to the Details layer in the Indoors model typically contains line features that you can use as input for the Obstacle Features parameter.
  12. Click the Entrance / Exit Features drop-down arrow, or click Browse, and choose a polyline feature class that represents the transition between indoor and outdoor spaces.
    Ensure that the selected entrance and exit features layer includes the FACILITY_ID, VERTICAL_ORDER_FROM, and VERTICAL_ORDER_TO fields. For the transition to be valid, place the transition line feature within 2 meters (6.5 feet) of both the Level layer border and IPS Areas layer border.
    You can use a layer that conforms to the Transitions layer in the Indoors model for the Entrance / Exit Features parameter, when the features representing entrances and exits are properly configured.
  13. Click Run.
The dataset is enhanced with traversability information. You can share this dataset as an indoor positioning data service and create an IPS-aware map.
The tool also creates a Derived Walkable Features polygon feature layer. You can use this layer to visually inspect the classification results and the traversable areas for each valid level. For example, you can use the Feature Type field in the output Derived Walkable Features layer to visualize indoor-outdoor transition areas (red polygon).
Classification grid geometry output showing walkable and non-walkable areas
The Feature Type field in the output Derived Walkable Features layer visualizes the classification result.
