ArcGIS.Desktop.Mapping Namespace / LayerFactory Class
    LayerFactory Class Methods
    For a list of all members of this type, see LayerFactory members.
    Public Methods
     NameDescription
    Public Method Gets if the the layer can be copied. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines if a new Layer instance using the specified LayerCreationParams can be created and added to the specified container. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Indicates whether a layer can be created from an Item.
    Public MethodIndicates whether Layers can be created using the specified BulkLayerCreationParams and added to the container.
    Public Method Copy a layer. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Create a group layer. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodOverloaded.
    Top
