ArcGIS.Desktop.Mapping Namespace / TOCMapPaneProviderPane Class
    TOCMapPaneProviderPane Class Methods
    For a list of all members of this type, see TOCMapPaneProviderPane members.
    Public Methods
     NameDescription
    Public Method Makes the Pane the active Pane and active window. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Public Method Close the Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Public Method Flashes the Pane's tab. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Public Method Invoked when an object is dragged over the window. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Public Method Invoked when an object is dropped onto the pane. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Public Method Sets the Map URI of the MapView whose TOC is to be shown when this pane is activated (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane)
    Top
    Protected Methods
     NameDescription
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Copy button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's CopyPath button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Cut button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Delete button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Duplicate button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's Paste button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method The active pane is constantly polled giving it the opportunity to enable the application's PasteSpecial button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Combines the Pane's state with the specified Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Called when the Copy command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the CopyPath command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Cut command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Delete command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the Duplicate command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Method Allows a Pane to override the state it sets when activated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected MethodOverridden.  Initializes the pane as part of its creation sequence.
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Protected Method Called when the pane is activated (receives focus - active is true) or deactivated (loses focus - active is false). (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane)
    Protected Method Override to implement special behavior when the active map view is changed. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane)
    Protected MethodOverridden.  Notification letting the Pane know it has been closed.
    Protected Internal Method Called when a request has been made to close the Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Provides the Pane with the option to customize its ContextMenu before it is displayed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Optional override to create the visible content of the control. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Notification letting the Pane know it has been docked. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when a mouse button is clicked two or more times. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Notification letting the Pane know it has been floated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected MethodOverridden.  Notification letting the Pane know it has been hidden.
    Protected Internal Method Called during OnKeyDown if when a register shortcut matches. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Occurs when a key is pressed while focus is on this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when a key is released while focus is on this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when any mouse button is pressed while the pointer is over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when the mouse pointer moves while over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when any mouse button is released over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected MethodOverridden.  Called the impersonated map pane is closed
    Protected Internal Method Occurs when a pointer is pressed while over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when a pointer is released over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Occurs when a touch event occurs over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Internal Method Called periodically by the framework once the tool has been created. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn)
    Protected Internal Method Called when the Paste command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Internal Method Called when the PasteSpecial command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase)
    Protected Method Process key down (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Method Stops the Pane from impersonating a different state. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane)
    Protected Method Called when the pane is uninitialized. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane)
    Top
