| Name | Description | |
![]() | _cimView | The view state of the window (Inherited from ArcGIS.Desktop.Core.ViewStatePane) |
![]() | _dockUnderMapView |
The following tables list the members exposed by TOCMapPaneProviderPane.
![]() | CanClose | Gets or sets whether the window may be closed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | Caption | Gets or sets the Pane's caption. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | ContentID | Allows derived classes to provide a unique identifier for the Pane. The DAML ID is returned by default. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | DisabledTooltip | Gets or sets the supplementary text that appears with the Tooltip only when the command is disabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | DockUnderMapView | Gets whether the pane should be docked under the active map view when opened |
![]() | Enabled | Gets or sets a boolean to specify whether the control is enabled. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | FullCaption | Gets the Pane's Caption including its GroupID count. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | GroupIndex | Gets the index assigned for the GroupID count. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | ID | Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | Initialized | Gets a boolean indicating whether the pane has been fully initialized or not. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | InstanceID | Gets the Framework assigned ID. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | IsBusy | Gets a boolean to let clients know the Pane is currently processing a Task. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | IsClosed | Gets a flag indicating if this pane has been closed. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | IsHidden | Gets a flag indicating if this pane has been hidden. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | LargeImage | Gets or sets the large representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | LoadingMessage | Gets or sets the message presented while the Pane is initializing. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | MapURI | Gets the Map URI (of the MapView) associated with this pane (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | MapView | Gets and sets the MapView whose TOC is associated with this pane (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | OperationManager | Overridden. Gets the OperationsManager associated with the Pane |
![]() | Secondary | Overridden. Gets the secondary flag value. Returns true if the pane can be positioned as a secondary pane "under" a Map View. |
![]() | SmallImage | Gets or sets the small representation of the command, this may be an image or a xaml element. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | State | Gets the Pane's state table. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | TabTooltip | Gets or sets the Pane's tab tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | ToolElement | Gets or sets the Pane's HwndHost if applicable. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | Tooltip | Gets or sets a brief description of the command that appears in a small pop-up window when a user pauses the mouse pointer over an element, such as over a Button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | TooltipHeading | Gets or sets a one or two word label that appears above the tooltip. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | ViewState | Gets the view state of the window (Inherited from ArcGIS.Desktop.Core.ViewStatePane) |
![]() | Content | Gets or sets the content portion of the Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | GroupID | Setting the GroupID property enables Pane numbering. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | IsPermanantHidden | For internal esri use only (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | Activate | Makes the Pane the active Pane and active window. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | Close | Close the Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | Flash | Flashes the Pane's tab. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnDragOver | Invoked when an object is dragged over the window. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | OnDrop | Invoked when an object is dropped onto the pane. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | OnMouseHWheel | Invoked when an object is dragged over the window. Implement this method to add class handling for this event. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | SetMapURI | Sets the Map URI of the MapView whose TOC is to be shown when this pane is activated (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | CanCopyAsync | The active pane is constantly polled giving it the opportunity to enable the application's Copy button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanCopyPathAsync | The active pane is constantly polled giving it the opportunity to enable the application's CopyPath button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanCutAsync | The active pane is constantly polled giving it the opportunity to enable the application's Cut button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanDeleteAsync | The active pane is constantly polled giving it the opportunity to enable the application's Delete button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanDuplicateAsync | The active pane is constantly polled giving it the opportunity to enable the application's Duplicate button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanPasteAsync | The active pane is constantly polled giving it the opportunity to enable the application's Paste button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CanPasteSpecialAsync | The active pane is constantly polled giving it the opportunity to enable the application's PasteSpecial button. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CombineState | Combines the Pane's state with the specified Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | CopyAsync | Called when the Copy command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CopyPathAsync | Called when the CopyPath command is clicked. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | CutAsync | Called when the Cut command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | DeleteAsync | Called when the Delete command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | DuplicateAsync | Called when the Duplicate command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | Impersonate | Allows a Pane to override the state it sets when activated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | InitializeAsync | Overridden. Initializes the pane as part of its creation sequence. |
![]() | NotifyPropertyChanged | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | OnActivate | Called when the pane is activated (receives focus - active is true) or deactivated (loses focus - active is false). (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | OnActiveMapViewChanged | Override to implement special behavior when the active map view is changed. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | OnClosed | Overridden. Notification letting the Pane know it has been closed. |
![]() | OnClosing | Called when a request has been made to close the Pane. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnContextMenu | Provides the Pane with the option to customize its ContextMenu before it is displayed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnCreateContent | Optional override to create the visible content of the control. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnDocked | Notification letting the Pane know it has been docked. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnDoubleClick | Occurs when a mouse button is clicked two or more times. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnFloated | Notification letting the Pane know it has been floated. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnHidden | Overridden. Notification letting the Pane know it has been hidden. |
![]() | OnKeyCommand | Called during OnKeyDown if when a register shortcut matches. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | OnKeyDown | Occurs when a key is pressed while focus is on this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnKeyUp | Occurs when a key is released while focus is on this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnMouseDown | Occurs when any mouse button is pressed while the pointer is over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnMouseMove | Occurs when the mouse pointer moves while over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnMouseUp | Occurs when any mouse button is released over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnNoActiveMapView | Overridden. Called the impersonated map pane is closed |
![]() | OnPointerDown | Occurs when a pointer is pressed while over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnPointerUp | Occurs when a pointer is released over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnTouch | Occurs when a touch event occurs over this element. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | OnUpdate | Called periodically by the framework once the tool has been created. (Inherited from ArcGIS.Desktop.Framework.Contracts.PlugIn) |
![]() | PasteAsync | Called when the Paste command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | PasteSpecialAsync | Called when the PasteSpecial command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.PaneBase) |
![]() | ProcessKeyDown | Process key down (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | SetProperty | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | Unimpersonate | Stops the Pane from impersonating a different state. (Inherited from ArcGIS.Desktop.Framework.Contracts.Pane) |
![]() | UninitializeAsync | Called when the pane is uninitialized. (Inherited from ArcGIS.Desktop.Mapping.TOCActiveMapViewProviderPane) |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
