ArcGIS.Core.CIM Namespace / CIMReportFooter Class
Properties Methods Events
    CIMReportFooter Class Members
    The following tables list the members exposed by CIMReportFooter.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether to force the subsection to export at the bottom of the page.
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the height of Text elements in sections will grow based on their content. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a value indicating whether the section height will grow and shrink to fit the content of the section. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the field properties that will be applied to the elements. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a collection of elements. (Inherited from ArcGIS.Core.CIM.CIMGroupElement)
    Public Property Gets or sets the comma delimited list of pages to exclude the page number from. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets the comma delimited list of pages to exclude the section from. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets a value indicating whether the section should be displayed in columns. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a value indicating whether to prevent a page break for a subsection. This property can be applied to the report footer, group header, and group footer subsections. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the section should start on a new page. (Inherited from ArcGIS.Core.CIM.CIMReportSectionElement)
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMReportFooter.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMReportFooter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMReportFooter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
