ArcGIS.Core.Data.Analyst3D Namespace / TinTriangle Class
    TinTriangle Class Properties
    For a list of all members of this type, see TinTriangle members.
    Public Properties
     NameDescription
    Public PropertyGets the area of this TIN triangle. The area is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyGets the 3D area of this TIN triangle. The area is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. If the triangle has NaN z-values, then NaN is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the aspect of this TIN triangle in radians. The aspect is the compass direction of the steepest downhill slope of the triangle. A value of 0 radians is due North, PI / 2 radians due East, PI radians due South, 3 * PI / 2 due West, etc. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the edges of this TIN triangle. The edges are ordered in a clockwise direction. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden. Gets the TinElementType of this instance. Always returns TinElementType.Triangle.
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyOverridden.  Gets a value indicating if this TIN element has Z-less vertices. If the z-value of a vertex is NaN, then it is considered z-less. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the index number of this TIN element. The base index number for TIN elements is 1. (Inherited from ArcGIS.Core.Data.Analyst3D.TinElement)
    Public Property Gets the intensity (i.e. brightness value) of this TIN triangle. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden.  Gets a value indicating whether or not this element is empty. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden. Gets if this element is within the interpolation zone or the data area of the TIN. See TinDataset.GetDataArea. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden. Gets the length (i.e. perimeter) of this TIN triangle. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyGets the 3D length (i.e. perimeter) of this TIN triangle. The length is in the units of the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. If the triangle has NaN z-values, then NaN is returned. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden.  Gets the node count of the element. Always returns 3.
    Public Property Gets the nodes of this TIN triangle. The nodes are ordered in a clockwise direction. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the slope of this TIN triangle in radians. This method must be called on the MCT. Use QueuedTask.Run.
    Public Property Gets the slope of this TIN triangle as a percent. This method must be called on the MCT. Use QueuedTask.Run.
    Public PropertyOverridden.  Gets the tag value of this TIN triangle. This method must be called on the MCT. Use QueuedTask.Run.
    Top
