ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class
    KnowledgeGraphMappingExtensions Class Methods
    For a list of all members of this type, see KnowledgeGraphMappingExtensions members.
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Appends a set of named object types and their records to the link chart map. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Determines if the set of named object types and their records can be appended to the link chart map. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Determines if the content of the link chart map can be cleared. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Determines if the set of named object types and their records can be applied to the link chart map using the specified IDSetCombinationMethod. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Clears the link chart map content. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Clears the root nodes for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets the layout algorithm for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets the set of root nodes as a MapMemberIDSet. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets whether non spatial data are displayed for the knowledge graph layer in the link chart map view.
    Public Methodstatic (Shared in Visual Basic) Gets whether root nodes are displayed for the link chart map view.
    Public Methodstatic (Shared in Visual Basic) Selects the existing set of root nodes defined on the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Selects the existing set of non spatial data in the knowledge graph layer on the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets AND selects the root nodes for the link chart map view. Use an empty set of rootNodes to clear the existing set of root nodes and the selection. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Selects the existing set of spatial data in the knowledge graph layer on the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Applies a set of named object types and their records to the link chart map using the specified IDSetCombinationMethod. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Overloaded.
    Public Methodstatic (Shared in Visual Basic) Sets the root nodes for the link chart map view. Use an empty set of rootNodes to clear the existing set of root nodes. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets whether non spatial data are displayed for the knowledge graph layer in the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Sets whether root nodes are displayed for the link chart map view. This method must be called on the MCT. Use QueuedTask.Run.
    Top
