ArcGIS.Core.CIM Namespace / CIMPresentationDocument Class
Properties Methods Events
    CIMPresentationDocument Class Members
    The following tables list the members exposed by CIMPresentationDocument.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the binary references in the document.
    Public Property Gets or sets the build an item was created with. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Public Property Gets or sets the elevation surface layer definitions in the document.
    Public Property Gets or sets the layer definitions in the document.
    Public Property Gets or sets the link chart definitions in the document.
    Public Property Gets or sets the map definitions in the document.
    Public Property Gets or sets the presentation definition in the document.
    Public Property Gets or sets the table definitions in the document.
    Public Property Gets or sets the timeline definitions in the document.
    Public Property Gets or sets document version. Set by the system. (Inherited from ArcGIS.Core.CIM.CIMVersion)
    Public Property Gets or sets the video definitions in the document.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMPresentationDocument.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMPresentationDocument with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMPresentationDocument and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
