ArcGIS.Core.CIM Namespace / CIMMapFrame Class
    CIMMapFrame Class Properties
    For a list of all members of this type, see CIMMapFrame members.
    Public Properties
     NameDescription
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the camera associated with the map frame.
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the extent indicators associated with the map frame.
    Public Property Gets or sets a value indicating whether the map frame extent indicators are expanded in the contents pane.
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the Grids and Graticules associated with the MapFrame.
    Public Property Gets or sets the array of layer visibility overrides.
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the map frame grids are expanded in the contents pane.
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether LayerVisibilityOverrides are used to override layer visibility.
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the path to the map in the project.
    Public Property Gets or sets a value indicating whether the MapFrame should use the Map background color.
    Public Property Gets or sets the view associated with the map frame.
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Top
