ArcGIS.Core.CIM Namespace / CIMBarChartMarker Class
Properties Methods Events
    CIMBarChartMarker Class Members
    The following tables list the members exposed by CIMBarChartMarker.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the specified location where all transformation property operations originate. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets a value which specifies if the anchor point location is considered a percentage of the size or as an absolute distance. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the angle the marker is rotated around the X axis. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the angle the marker is rotated around the Y axis. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the animations that are applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the axes symbol.
    Public Property Gets or sets the billboard mode of the marker. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets a value indicating whether the color set at the basic properties level is applied to the symbol layer. If the symbol layer is color locked then changes made to the color in the basic properties will not be applied to the symbol layer. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether to draw the chart with a 3D perspective. (Inherited from ArcGIS.Core.CIM.CIMChartMarker)
    Public Property Gets or sets which axis is considered as the Size in 3D. Only applicable when the marker layer is a 3DShapeMarker. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets whether the geometric effects that are applied to the symbol layer. Effects dynamically alter the feature geometry when the symbology is applied. Multiple effects applied to a symbol layer are rendered sequentially. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether the symbol layer is visible. The symbol layer draws only when enabled. Currently, an invisible layer is not considered in any transformations when in a 3D context. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets marker placements which determine how markers are placed along a line or within a polygon. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the internal name of the symbol layer used for symbol level drawing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the value the marker is moved along the X axis from the anchor point. This is applied after all rotation, as opposed to anchor point which is applied before the rotation. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the value the marker is moved along the Y axis from the anchor point. This is applied after all rotation, as opposed to anchor point which is applied before the rotation. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the value the marker is moved along the Z axis from the anchor point. This is applied after all rotation, as opposed to anchor point which is applied before the rotation. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets a value indicating whether or not the symbol layer should overprint in press printing. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets the individual components of the chart marker. (Inherited from ArcGIS.Core.CIM.CIMChartMarker)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMSymbolLayer)
    Public Property Gets or sets a value indicating whether the rotation is applied clockwise or counterclockwise to the marker layer. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the angle that the marker is rotated around the anchor point, in degrees. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets a value indicating whether or not to show the axes symbol.
    Public Property Gets or sets the height of the marker. Modifying Size changes the marker's height to the specified size and the width is updated proportionally. (Inherited from ArcGIS.Core.CIM.CIMMarker)
    Public Property Gets or sets the spacing.
    Public Property Gets or sets the thickness or depth of a chart. Only applied when Display3D is true. (Inherited from ArcGIS.Core.CIM.CIMChartMarker)
    Public Property Gets or sets the tilt (rotation around the X axis) of the chart. Only applied when Display3D is true. (Inherited from ArcGIS.Core.CIM.CIMChartMarker)
    Public Property Gets or sets a value indicating whether this bar chart marker has vertical bars.
    Public Property Gets or sets the width.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBarChartMarker.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBarChartMarker with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBarChartMarker and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
