ArcGIS.Core.CIM Namespace / CIMRasterShadedReliefColorizer Class
Properties Methods Events
    CIMRasterShadedReliefColorizer Class Members
    The following tables list the members exposed by CIMRasterShadedReliefColorizer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the Altitude. The value will be ignored if UseMapIlluminationProperties is set to true.
    Public Property Gets or sets the azimuth. The value will be ignored if UseMapIlluminationProperties is set to true.
    Public Property Gets or sets the brightness value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the color ramp.
    Public Property Gets or sets the contrast value. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the hillshade type.
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the no data color. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the pixel size factor.
    Public Property Gets or sets the pixel size power.
    Public Property Gets or sets a value indicating whether or not to remove edge effect.
    Public Property Gets or sets the raster resampling type. (Inherited from ArcGIS.Core.CIM.CIMRasterColorizer)
    Public Property Gets or sets the scaling type.
    Public Property Gets or sets a value indicating whether or not to use map level illumination properties of altitude and azimuth.
    Public Property Gets or sets a scaling factor used to convert the elevation values.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMRasterShadedReliefColorizer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMRasterShadedReliefColorizer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMRasterShadedReliefColorizer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
