Feature builder reference
Feature builders are semiautonomous feature constructors by which group templates create and place features relative to the primary feature geometry that is sketched with a group template construction tool.
Some builders include definable parameters that allow you to control the placement of features along the sketched geometry, for example, the distance from a vertex at which a point feature is created.
The feature builders listed below are assigned and configured in the Template Properties dialog box on the Builders side tab.
Feature builders
Primary template geometry |
Feature template geometry |
Feature builder |
Point |
Point |
Point |
Line |
Point |
Polygon |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Point or Line |
Point |
Line |
Not Applicable |
This builder is available only to primary templates with the line toolset. |
Line |
Not Applicable |
This builder is available only to primary templates with the line toolset. Note:If the features created by the group template are members of a utility network, a connectivity association record is created between the first point feature and the primary template line feature. |
Line |
Line |
Line |
Line |
This builder is also available to primary templates with the line toolset but overrides the continuous line tool and sketches two-point lines. |
Line |
Polygon |
Polygon |
Point |
Polygon |
Point |
Polygon |
Point |
Polygon |
Point |
Polygon |
Line |
Polygon |
Line |
Polygon |
Polygon |
Polygon |
Polygon |
