ArcGIS.Core.CIM Namespace / CIMSizeClassBreaksVisualVariable Class
    CIMSizeClassBreaksVisualVariable Class Properties
    For a list of all members of this type, see CIMSizeClassBreaksVisualVariable members.
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to automatically update class labels whenever a class upper value is changed.
    Public Property Gets or sets the authoring info. (Inherited from ArcGIS.Core.CIM.CIMVisualVariable)
    Public Property Gets or sets size visual variable axis. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the class breaks.
    Public Property Gets or sets the legend display options.
    Public Property Gets or sets the classification method.
    Public Property Gets or sets the data values. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the default description.
    Public Property Gets or sets the default label.
    Public Property Gets or sets the default symbol.
    Public Property Gets or sets the custom patch for the default symbol.
    Public Property Gets or sets the patch shape for the default symbol.
    Public Property Gets or sets a value indicating whether or not to draw size marker symbols for polygon features above all layers.
    Public Property Gets or sets the expression. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the maximum size. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the maximum value. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the minimum break.
    Public Property Gets or sets the minimum size. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the minimum value. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the normalization field. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the data normalization method. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the number format.
    Public Property Gets or sets the random maximum. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the random minimum. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets a value indicating whether or not to show class gaps.
    Public Property Gets or sets a value indicating whether or not to show classes in ascending order.
    Public Property Gets or sets the size values that correspond to data values. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets size visual variable target which specifies the portion of the symbol targeted for sizing. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the template symbol.
    Public Property Gets or sets a value indicating whether or not to use class breaks.
    Public Property Gets or sets a value indicating whether or not to use the default symbol.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the value representations. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the value shape. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets the size visual variable type. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Public Property Gets or sets size visual variable type. (Inherited from ArcGIS.Core.CIM.CIMSizeVisualVariable)
    Top
