ArcGIS.Core.Data Namespace / CoreDataExtensions Class
    CoreDataExtensions Class Methods
    For a list of all members of this type, see CoreDataExtensions members.
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Registers an extension id (guid) with the specified table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Updates a circuit row in the circuit table with the provided argument's values. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Inserts a circuit row in the circuit table with the provided argument's values. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Mark the given circuits as deleted. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Evaluates all the applicable tables and feature classes in the geodatabase associated with attributeRuleManager using the operation(s) specified by description. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets the readonly list of extension ids (guids) registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets the CIMDataConnection for the specified dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets the CIMDataConnections for the specified datasets. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Gets if the specified extension id (guid) is registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Marks the topology error specified by topologyError as an exception. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Partial posts this version against a target version specified in partialPostOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Posts this version against a target version specified in postOptions. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Overloaded.
    Public Methodstatic (Shared in Visual Basic) Refreshes the version and layers in all maps that references this version. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Removes the extension id (guid) from being registered with the table. This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Reserves a range to create a gap in the unit range ArcGIS.Core.Data.UtilityNetwork.Telecom.UnitRange space of an equipment container. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Removes gaps and resets the unit space to be contiguous within an equipment hierarchy. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Updates the number of units in an equipment container. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Resets the topologyError currently marked as an exception to once again be an error. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Updates the validation error system tables specified by validationErrors. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic)Ensures data integrity by validating the features in a topology in the area specified by ArcGIS.Core.Data.Topology.ValidationDescription.Extent against a pre-defined set of topology rules. This method must be called on the MCT. Use QueuedTask.Run.
    Public Methodstatic (Shared in Visual Basic) Updates the status of a list of circuits. This method must be called on the MCT. Use QueuedTask.Run.
    Top
