ArcGIS.Core.CIM Namespace / CIMFilteredFindPathsConfiguration Class
    CIMFilteredFindPathsConfiguration Class Properties
    For a list of all members of this type, see CIMFilteredFindPathsConfiguration members.
    Public Properties
     NameDescription
    Public Property Gets or sets the closed path policy, i.e whether we allow, forbid, or require that the start and end vertices of a path are equal. When the value is KGClosedPathPolicy.Require, the DestinationEntities field is ignored and destinations entities are the same as origin entities.
    Public Property Gets or sets the default relationship cost. If the default relationship cost is negative, it is replaced by zero.
    Public Property Gets or sets the default traversal direction which is used for any relationship type that is not defined in the traversal directions list.
    Public Property Gets or sets the destination entities. This field is ignored when ClosedPathPolicy is KGClosedPathPolicy.Require.
    Public Property Gets or sets the usage of origin/destination entities in the filtered find paths algorithm.
    Public Property Gets or sets the max number of paths the filtered find paths algorithm returns. This parameter is only taken into account when PathMode is KGPathMode.All.
    Public Property Gets or sets the maximum path cost. The maximum cost is only enforced when the value is positive.
    Public Property Gets or sets the maximum path length. The default of 0 means the value is unlimited.
    Public Property Gets or sets the minimum path cost.
    Public Property Gets or sets the minimum path length.
    Public Property Gets or sets the name of the configuration.
    Public Property Gets or sets the behaviour when a negative cost is found.
    Public Property Gets or sets the origin entities.
    Public Property Gets or sets the path filters.
    Public Property Gets or sets whether the filtered find paths algorithm searches for shortest paths, for lowest cost paths or for all paths.
    Public PropertyGets or sets the name of the property representing the cost of a relationship. If a relationship lacks this property, the property is not of a numeric type, or the property value is null, the cost of the relationship will be DefaultRelationshipCost. Only positive costs are supported. Any strictly negative cost will be converted to a positive cost based on NegativeCostBehaviour.
    Public Property Gets or sets the time filter.
    Public Property Gets or sets the traversal directions.
    Top
