ArcGIS.Core.Data.Raster Namespace / FunctionRasterDataset Class
Properties Methods
    FunctionRasterDataset Class Members
    The following tables list the members exposed by FunctionRasterDataset.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyGets the ArcGIS.Core.Data.DatasetType of this raster dataset. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Top
    Public Methods
     NameDescription
    Public MethodCreates a Raster that has the same properties of this basic raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.BasicRasterDataset)
    Public MethodCreates a Raster that has the same properties and all the bands in this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public MethodCreates a Raster that has the same properties and the given list of bands from this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodGets a RasterBand from this raster dataset based on the band index. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public MethodGets a RasterBand from this raster dataset based on the band name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets the number of bands in this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets the index for a band in this raster dataset based on the band name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets a key property for a band in this raster dataset based on band index and key property name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets the complete name of this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.BasicRasterDataset)
    Public Method Gets the data store of this dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the RasterDatasetDefinition of this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets the extent of this raster dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets a key property of this raster dataset based on the key property name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Public Method Gets the name of the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets the URI path to the dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public MethodGets the ArcGIS.Core.Data.RegistrationType of a dataset. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Dataset)
    Public Method Gets a value indicating whether this raster dataset is empty. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Raster.RasterDataset)
    Top
    Extension Methods
     NameDescription
    Public Extension Method Gets the CIMDataConnection for the specified dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets whether the dataset is a knowledge graph dataset or not. This method must be called on the MCT. Use QueuedTask.Run.
    Top
