Pairwise Intersect (Analysis Tools)
Summary
Computes a pairwise intersection of the input features. Features or portions of features that overlap between the input feature layers or feature classes will be written to the output feature class. Pairwise intersection refers to selecting one feature from the first input and intersecting it with the features in the second input that it overlaps.
An alternate tool is available for intersect operations. See the Intersect tool documentation for details.
The Pairwise Intersect tool is similar to the Intersect tool in that geometric intersections are computed, but it is different in that intersections are computed on pairs of features rather than all combinations of features.
Learn more about how Pairwise Intersect works
Illustration
Pairwise Intersect tool illustration
Usage
  • Only two input feature classes are supported.
  • The input must be simple features, such as point, multipoint, line, or polygon features. You cannot use complex features such as annotation features, dimension features, or network features.
  • If the inputs have different geometry types, the output geometry type will default to the lowest dimension of the inputs.
    • If an input is point features, the default output will be point features.
    • If an input is line features, and there are no inputs with point features, the default output will be line features.
    • If all inputs are polygon features, the default output will be polygon features.
  • The Output Type parameter value can be that of the Input Features parameter value with the lowest dimension geometry or lower. For example, if all the inputs are polygons, the output can be polygon, line, or point. If one of the inputs is of type line and none are points, the output can be line or point. If any of the inputs are point, the Output Type value can only be point.
  • The Use maximum precision parameter only applies when the Output Type parameter value is Point. Precision is a combination of the x,y resolution and x,y tolerance that is used during processing. The default is to use these properties from the first Input Features feature class' spatial reference.
    When the Precision parameter is checked, the maximum possible precision value will be used for point output. The tool uses the maximum accuracy that is available to the tool, which depends on the absolute value of the geometry coordinates and the accuracy of the hardware floating point. A rough estimate of the maximum tolerance that will be used is 0.002 millimeters as compared to 1 millimeter for the default.
    When the output is written, the resolution of the spatial reference will be applied so the points may shift slightly.
    When the input data contains non-linear segments (curves), for best results enable the Maintain Curve Segments environment and set the Curve Processing Method environment to EXACT.
  • Unlike the Intersect tool, ranks are not supported.
  • By default, curve features from the input will be densified in the output. To support curves in the output, use the Maintain Curve Segments environment.
  • All inputs must have a spatial index. Use the Add Spatial Index tool to create an index (particularly for shapefiles) or rebuild an existing index if there is any possibility that it is incorrect.
  • When the input features have m- or z-values, only the m- and z-values of the first feature class will be transferred to the output features. If the first feature class does not contain m- or z-values, the output will not contain m- or z-values.
  • The spatial reference of the output feature class will be that of the first feature class in the Input Features parameter. See Spatial reference and geoprocessing for more information.
  • This tool honors the Parallel Processing Factor environment. If the environment is not set (the default) or is set to 100, full parallel processing will be enabled and the tool will attempt to distribute the work to all the logical cores on the machine. If the environment is set to 0, parallel processing will not be enabled. If a factor between 1 and 99 is specified, the tool will identify the percentage of logical cores to use by applying the formula (Parallel Processing Factor / 100 * Logical Cores) rounded up to the nearest integer. If the result of this formula is 0 or 1, parallel processing will not be enabled.
Parameters
Label Explanation Data type
Input Features
The input feature classes or layers that will intersect. Only two inputs are supported.
Value Table
Output Feature Class
The output feature class.
Feature Class
Join Attributes
(Optional)
Specifies which attributes from the input features will be transferred to the output feature class.
  • All attributes—All the attributes from the input features will be transferred to the output feature class. This is the default.
  • All attributes except feature IDs—All the attributes except the FID from the input features will be transferred to the output feature class.
  • Only feature IDs—Only the FID field from the input features will be transferred to the output feature class.
String
XY Tolerance
(Optional)
The minimum distance separating all feature coordinates (nodes and vertices) as well as the distance a coordinate can move in x or y (or both).
Caution:
Changing this parameter's value may cause failure or unexpected results. It is recommended that you do not modify this parameter. It has been removed from view on the tool dialog box. By default, the input feature class's spatial reference x,y tolerance property is used.
Linear Unit
Output Type
(Optional)
Specifies the type of intersections that will be returned.
  • Same as input—The intersections returned will be the same geometry type as the input features with the lowest dimension geometry. If all inputs are polygons, the output feature class will contain polygons. If one or more of the inputs are lines and none of the inputs are points, the output will be lines. If one or more of the inputs are points, the output feature class will contain points. This is the default.
  • Line—The intersections returned will be line. This is only valid if none of the inputs are points.
  • Point—The intersections returned will be point. If the inputs are line or polygon, the output will be a multipoint feature class.
String
(Optional)
Specifies the level of precision that will be used when the Output Type parameter value is Point. This parameter is not supported when the Output Type parameter value is Same as input or Line. Check this parameter when you want the tool to apply a level of accuracy that is greater than the default for the input spatial reference when determining point output.
  • Checked—Maximum precision will be used in determining point output.
  • Unchecked—The precision of the first input feature class will be used in determining point output. This is the default.
Boolean
Environments
Auto Commit, Maintain fully qualified field names, Default Output Z Value, M Resolution, M Tolerance, Output CONFIG Keyword, Output M Domain, Output XY Domain, Output Z Domain, Output Coordinate System, Geographic Transformations, Extent, Output has M values, Output has Z values, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Parallel Processing Factor, Maintain Curve Segments, Curve Processing Method, Transfer Geodatabase Field Properties
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
