Aggregate Polygons (Cartography Tools)
Summary
Combines polygons that are within a specified distance of each other into new polygons.
Illustration
Aggregate Polygons tool illustration
Orthogonal or nonorthogonal features can be aggregated.
Usage
  • This tool is intended for moderate scale reduction and aggregation when input features can no longer be represented individually due to the limited map space or the required data resolution. Aggregation will only occur when two polygon boundaries are within the specified aggregation distance of each other. There will be no self-aggregation, meaning no aggregation within an input polygon feature itself along its boundary, and no aggregation between any parts of a multipart polygon feature.
  • Using the orthogonal option will construct orthogonally shaped output features. This option is best suited for input features that have predominantly orthogonal edges. In some cases, less aggregation will occur to accommodate this. For example, two square buildings situated diagonally apart within the aggregation distance may not be aggregated because there is no clear connection that can be made while preserving orthogonality. The nonorthogonal option will produce more organically shaped results.
  • Use barrier features to prevent aggregation from occurring across boundaries. Examples include preventing land cover from aggregating across rivers, or buildings aggregating across streets. Barriers can be either lines or polygons, and multiple barrier feature classes can be used simultaneously.
  • When the Aggregate Field parameter is specified, the attribute field and its values will be copied to the output feature class. The aggregate field must be of data type text, date, or integer. If the aggregate field has domains and subtypes, they will be copied to the output feature class when the Transfer Geodatabase Field Properties environment is checked.
  • Overlapping polygon features will be aggregated. Unexpected results may occur if the Aggregate Field parameter is specified and overlapping features have different aggregate field values.
  • The output feature class will not contain any geographic attributes from the input features. A one-to-many relationship table can be created to link the aggregated polygons to their source polygons. This link can become incorrect when any of the input or output features are modified.
  • If the input features contain z-values, the z-values can be preserved if they're specified in the environment settings. If the output vertices do not change, the input z-values will be carried over to the output vertices; otherwise, a z-value will be derived for new vertices, either from existing z-values or through interpolation.
  • Polygons with many vertices and small holes can slow the tool's processing time. To improve performance, use the Simplify Polygon tool to reduce the number of vertices, and use the Eliminate Polygon Part tool to remove small holes.
  • Processing a large input dataset may exceed memory limitations. In this case, consider processing input data by partition by identifying a relevant polygon feature class in the Cartographic Partitions environment. Portions of the data, defined by partition boundaries, will be processed sequentially. The resulting output feature class will be consistent at partition edges, but output features that cross partitions will be split at the partition line. The IS_SPLIT field in the output feature class will have a value of 1 in this instance.
Parameters
Label Explanation Data type
Input Features
The polygon features that will be aggregated. If this is a layer referencing a representation, and shape overrides are present on the input features, the overridden shapes, not the feature shapes, will be considered in aggregation processing.
Feature Layer
Output Feature Class
The output feature class that will be created.
Feature Class
Aggregation Distance
The distance that will be satisfied between polygon boundaries for aggregation to occur. A distance must be specified, and it must be greater than zero. You can choose a preferred unit; the default is the feature unit.
Linear Unit
Minimum Area
(Optional)
The minimum area for an aggregated polygon to be retained. The default value is zero, that is, to keep all polygons. You can specify a preferred unit; the default is the feature unit.
Areal Unit
Minimum Hole Size
(Optional)
The minimum size of a polygon hole to be retained. The default value is zero, that is, to keep all polygon holes. You can specify a preferred unit; the default is the feature unit.
Areal Unit
Preserve orthogonal shape
(Optional)
Specifies the characteristic of the output features when constructing the aggregated boundaries.
  • Checked—Orthogonally shaped output features will be created. This is suitable for preserving the geometric characteristic of anthropogenic input features, such as building footprints.
  • Unchecked—Organically shaped output features will be created. This is suitable for natural features, such as vegetation or soil polygons. This is the default.
Boolean
Barrier Features
(Optional)
The layers containing the line or polygon features that are aggregation barriers for input features. Features will not be aggregated across barrier features. Barrier features that are in geometric conflict with input features will be ignored.
Feature Layer
Output Table
(Optional)
A one-to-many relationship table that links the aggregated polygons to their source polygon features. This table contains two fields, OUTPUT_FID and INPUT_FID, that store the aggregated feature IDs and their source feature IDs, respectively. Use this table to derive necessary attributes for the output features from their source features. The default name for this table is the name of the output feature class, appended with _tbl. The default path is the same as the output feature class. If the output features location is specified in a feature dataset, this table will be created one level higher, at the geodatabase level. No table is created when this parameter is left blank.
Table
Aggregate Field
(Optional)
The field that contains attributes for aggregation. Features must share the same attribute value to be considered for aggregation. For example, use a building classification field as the aggregate field to prevent commercial buildings from aggregating with residential buildings.
Field
Environments
Current Workspace, Default Output Z Value, Output M Domain, Output XY Domain, Output Coordinate System, Extent, Output has M values, Output has Z values, Scratch Workspace, XY Tolerance, Cartographic Partitions
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
