A complete listing of the Spatial Analyst tools
Available with Spatial Analyst license.
The ArcGIS Spatial Analyst extension has over 200 tools in 22 toolsets for performing spatial analysis and modeling.
Spatial Analyst toolsets
Toolset
Tools
Conditional
Con • Pick • Set Null
Density
Calculate Kernel Density Ratio • Kernel Density • Line Density • Point Density • Raster to Weighted Points • Space Time Kernel Density • Value Percentile Contour • Volume Percentile Contour
Distance
Distance Accumulation • Distance Allocation • Least Cost Corridor • Optimal Corridor Connections • Optimal Path as Line • Optimal Path as Raster • Optimal Region Connections
Distance (Legacy)
Corridor • Cost Allocation • Cost Back Link • Cost Connectivity • Cost Distance • Cost Path • Cost Path as Polyline • Euclidean Allocation • Euclidean Back Direction • Euclidean Direction • Euclidean Distance • Path Distance • Path Distance Allocation • Path Distance Back Link
Extraction
Extract by Attributes • Extract by Circle • Extract by Mask • Extract by Points • Extract by Polygon • Extract by Rectangle • Extract Multi Values to Points • Extract Values to Points • Sample
Generalization
Aggregate • Boundary Clean • Expand • Majority Filter • Nibble • Region Group • Shrink • Thin
Groundwater
Darcy Flow • Darcy Velocity • Particle Track • Porous Puff
Hydrology
Adjust Raster to Stream • Adjust Stream to Raster • Basin • Derive Continuous Flow • Derive Stream As Line • Derive Stream As Raster • Fill • Flow Accumulation • Flow Direction • Flow Distance • Flow Length • Generate Breach Lines • Geodesic Flow Direction • Locate Depressions • Sink • Snap Pour Point • Storage Capacity • Stream Link • Stream Order • Stream to Feature • Validate Flow Direction • Watershed
Interpolation
IDW • Kriging • Natural Neighbor • Spline • Spline with Barriers • Topo to Raster • Topo to Raster by File • Trend
Local
Cell Statistics • Combine • Equal to Frequency • Greater Than Frequency • Highest Position • Less Than Frequency • Lowest Position • Popularity • Rank
Map Algebra
Raster Calculator
Math (general)
Abs • Divide • Exp • Exp10 • Exp2 • Float • Int • Ln • Log10 • Log2 • Minus • Mod • Negate • Plus • Power • Round Down • Round Up • Square • Square Root • Times
Math Bitwise
Bitwise And • Bitwise Left Shift • Bitwise Not • Bitwise Or • Bitwise Right Shift • Bitwise XOr
Math Logical
Boolean And • Boolean Not • Boolean Or • Boolean XOr • Combinatorial And • Combinatorial Or • Combinatorial XOr • Diff • Equal To • Greater Than • Greater Than Equal • In List • Is Null • Less Than • Less Than Equal • Not Equal • Over • Test
Math Trigonometric
ACos • ACosH • ASin • ASinH • ATan • ATan2 • ATanH • Cos • CosH • Sin • SinH • Tan • TanH
Multidimensional Analysis
Aggregate Multidimensional Raster • Dimensional Moving Statistics • Generate Multidimensional Anomaly
Multivariate
Band Collection Statistics • Class Probability • Create Signatures • Dendrogram • Edit Signatures • Iso Cluster • Iso Cluster Unsupervised Classification • Maximum Likelihood Classification • Principal Components
Neighborhood
Block Statistics • Filter • Focal Flow • Focal Statistics • Line Statistics • Point Statistics
Overlay
Fuzzy Membership • Fuzzy Overlay • Locate Regions • Multicriteria Overlay • Weighted Overlay • Weighted Sum
Proximity
Generate Weighted Voronoi
Raster Creation
Create Constant Raster • Create Normal Raster • Create Random Raster
Reclass
Lookup • Reclass by ASCII File • Reclass by Table • Reclassify • Rescale by Function • Slice
Segmentation and Classification
Classify Raster • Compute Confusion Matrix • Compute Segment Attributes • Create Accuracy Assessment Points • Export Training Data For Deep Learning • Generate Training Samples From Seed Points • Inspect Training Samples • Linear Spectral Unmixing • Remove Raster Segment Tiling Artifacts • Segment Mean Shift • Train Iso Cluster Classifier • Train K-Nearest Neighbor Classifier • Train Maximum Likelihood • Train Random Trees Classifier • Train Support Vector Machine Classifier • Update Accuracy Assessment Points
Solar Radiation
Area Solar Radiation • Feature Solar Radiation • Points Solar Radiation • Raster Solar Radiation • Solar Radiation Graphics
Surface
Add Surface Information • Aspect • Contour • Contour List • Contour with Barriers • Curvature • Cut Fill • Feature Preserving Smoothing • Geomorphon Landforms • Geodesic Viewshed • Hillshade • Interpolate Shape • Multiscale Surface Deviation • Multiscale Surface Difference • Multiscale Surface Percentile • Observer Points • Slope • Surface Area Ratio • Surface Parameters • Top Hat Transform • Topographic Position Index • Viewshed • Visibility
Zonal
Tabulate Area • Zonal Characterization • Zonal Fill • Zonal Geometry • Zonal Geometry as Table • Zonal Histogram • Zonal Statistics • Zonal Statistics as Table
Spatial Analyst geoprocessing toolsets and tools
