Territory Design toolbox history
Available with Business Analyst license.
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Add Level Variables
Version
2.2
New at this version
Add Territory Barriers
Version
2.4
New at this version
Add Territory Level
Version
2.2
New at this version
Add Territory Seed Points
Version
2.9
New at this version
Copy Territory Solution
Version
2.8
New at this version
Create Territory Level Feature Classes
Version
2.9
Parameter feature_classes has 4 new options:
  • LINE_BARRIERS
  • SEED_POINTS
  • RESTRICTED_AREAS
  • POLYGON_BARRIERS
2.3
New at this version
Create Territory Solution
Version
2.6
New parameter added: in_boundary_mask
2.2
New at this version
Export Territory Solution
Version
2.3
New at this version
Generate Territory Report
Version
3.1
Parameter comparison_level had new option added: ALL_LEVELS
Parameter level had new option added: ALL_LEVELS
2.7
Parameter report_type has 2 new options:
  • REALIGNMENT
  • REALIGNMENT_DETAILED
2.6
New at this version
Import Territory Solution
Version
2.2
New at this version
Load Territory Records
Version
2.2
New at this version
Make Territory Solution Layer
Version
2.5
New at this version
Rebuild Territory Solution
Version
2.6
2.5
New at this version
Set Balance Variables
Version
2.2
New at this version
Set Territory Attribute Constraints
Version
2.3
New at this version
Set Territory Distance Parameters
Version
2.4
6 new parameters added:
  • time_zone
  • search_tolerance
  • network_datasource
  • build_index
  • travel_direction
  • time_of_day
Parameter units has 4 new options:
  • MINUTES
  • HOURS
  • SECONDS
  • DAYS
2.3
New at this version
Set Territory Level Options
Version
2.7
2 new parameters added:
  • spatial_relationship
  • buffer_tolerance
2.6
New parameter added: random_seed
2.3
New at this version
Solve Territories
Version
3.6
Parameter method has two new options:
  • OPTIMAL_MAX_TCOUNT
  • OPTIMAL_MIN_TCOUNT
3.3
  • PREFERRED
  • OPTIMAL_MAX_COVERAGE
3.0
3 new parameters added:
  • iterations_limit
  • algorithm
  • candidate_solutions
2.6
New parameter added: quality
2.2
New at this version
Validate Territories
Version
3.1
New at this version
