Territory Design toolbox licensing
Toolset/Tool
Basic
Standard
Advanced
Analysis toolset
Add Level Variables
Requires Business Analyst
Add Territory Barriers
Add Territory Seed Points
Set Balance Variables
Set Territory Attribute Constraints
Set Territory Distance Parameters
Requires locally installed network routing data.
Set Territory Level Options
Solve Territories
Validate Territories
Territory Solution toolset
Add Territory Level
Copy Territory Solution
Create Territory Level Feature Classes
Create Territory Solution
Export Territory Solution
Generate Territory Report
Import Territory Solution
Load Territory Records
Make Territory Solution Layer
Rebuild Territory Solution
