Business Analyst toolbox history
需要具有 Business Analyst 许可才能使用。
下表记录了对该工具箱中的每个工具所进行的更改。 每个工具对应一张表,您可以单击工具名称以转至工具参考页面。
有关如何解读和使用这些表的详细信息,请参阅工具箱历史记录主题。
Add Field Based Suitability Criteria
Version
2.2
New at this version
Add Point Layer Based Suitability Criteria
Version
2.2
New at this version
Add Variable Based Suitability Criteria
Version
2.2
New at this version
Analyze Market Area Gap
Version
2.6
New at this version
Analyze Market Potential
Version
2.6
New at this version
Assign Customers By Distance
Version
2.6
New at this version
Calculate Market Penetration
Version
2.3
New at this version
Calculate Suitability Score
Version
2.2
New at this version
Color Coded Layer
Version
3.7
Parameter area_of_interest has new option added: Point
3.5
3 new parameters added:
  • secondary_variable
  • grid_size
  • renderer_type
Parameter classification_method has new option added: STD_DEV
3.4
New parameter added: boundary_mode
3.3
4 new parameters added:
  • area_of_interest
  • out_dataset
  • out_dataset_path
  • out_dataset_name
Parameter classification_method has new option added: AUTO
2.2
License changed from Advanced to Basic
New parameter added: out_analysis_layer
Parameter removed: out_layer
2.1
New at this version
Create Target Group
Version
2.6
New at this version
Enrich Layer
Version
3.0
New environment added: geographicTransformations
2.2
Required Extension changed from None to UNKNOWN
2 parameters removed:
  • data_collection
  • country
Parameter order changed at parameter 3:
  • Old parameter: country
  • New parameter: variables
2.1
New at this version
Export Segmentation Profile
Version
2.6
New at this version
Find Nearby Locations
Version
3.0
New parameter added: location_name
2.8
New at this version
Generate Approximate Drive Times
Version
2.7
New at this version
Generate Customer Demographic Profile Report
Version
3.7
New at this version
Generate Customer Derived Trade Areas
Version
2.7
2 new parameters added:
  • minimum_step
  • target_percent_diff
2.6
8 new parameters added:
  • iterations_limit
  • time_of_day
  • distance_type
  • search_tolerance
  • polygon_detail
  • time_zone
  • units
  • travel_direction
Parameter method has 2 new options:
  • THRESHOLD_DRIVETIMES
  • THRESHOLD_RINGS
2.2
2.1
New at this version
Version
3.7
New at this version
Generate Customer Segmentation Profile
Version
2.5
New at this version
Generate Desire Lines
Version
2.9
5 new parameters added:
  • create_report
  • report_title
  • report_folder
  • report_format
  • output_report
2.2
New at this version
Generate Drive Time Trade Area
Version
3.0
2.7
  • input_method
  • expression
Parameter distances changed from Required to Optional
2.4
New at this version
Generate Geographies from Overlay
Version
3.0
2.3
New at this version
Generate Grids and Hexagons
Version
3.2
New parameter added: out_centroids
3.0
New at this version
Generate Market Area Segmentation Profile
Version
2.5
New at this version
Generate Points from Business Listings
Version
3.5
New parameter added: style
3.3
New parameter added: find_related_poi
3.2
Default value for parameter max_count changed from 1000000 to 5000
2.7
New parameter added: business_dataset
2.4
New at this version
Generate Segmentation Profile Report
Version
2.6
New at this version
Generate SDCX Index
Version
2.5
New at this version
Generate Standard Geography Trade Areas
Version
2.2
New at this version
Generate Survey Report For Profile
Version
2.6
New at this version
Generate Survey Report For Targets
Version
2.6
New at this version
Generate Target Group Layer
Version
2.5
New at this version
Generate Target Layer
Version
2.5
New at this version
Generate Target Penetration Layer
Version
2.5
New at this version
Generate Threshold Drive Times
Version
3.0
2.7
  • input_method
  • expression
  • minimum_step
Parameter threshold_values changed from Required to Optional
2.6
New parameter added: iterations_limit
2.5
New at this version
Generate Threshold Rings
Version
3.0
  • minimum_step
2.7
  • input_method
  • expression
2.5
New at this version
Generate Trade Area Rings
Version
3.0
2.7
  • input_method
  • expression
Parameter radii changed from Required to Optional
2.6
New parameter added: dissolve_option
2.3
New at this version
Huff Model
Version
2.4
New at this version
Huff Model Calibration
Version
2.5
New at this version
Import Business Analyst Report Template
Version
3.1
New at this version
Import Segmentation Profile
Version
2.6
New at this version
Import Survey Profiles
Version
2.6
New at this version
Make Suitability Analysis Layer
Version
3.4
  • out_dataset_name
  • out_dataset_path
2.2
New at this version
Measure Cannibalization
Version
3.0
2.5
New at this version
Remove Suitability Criteria
Version
2.3
New at this version
Remove Overlap
Version
2.7
Parameter define_trade_area changed from Required to Optional
2.6
New at this version
Remove Overlap (multiple)
Version
2.7
New at this version
Set Criteria Properties
Version
3.4
  • criteria_score_preset
  • preprocessing
  • criteria_score_method
  • final_score_method
2.2
New at this version
Set Target Site
Version
3.4
New at this version
Summary Reports
Version
3.5
New parameter added: report_style
3.2
  • add_infographic_data_source
  • add_infographic_header
  • add_infographic_footer
3.0
2.9
New parameter added: report_per_feature
2.2
Default value for parameter subtitle changed from Prepared By Business Analyst Pro to Prepared By Business Analyst for ArcGIS Pro
2.1
New at this version
