Replication and geodatabase compatibility
Available with Standard or Advanced license.
Geodatabase replication in ArcGIS Pro provides support for multiple replication types and dataset types.
Versioning options
Branch versioning is not supported for any data source in any geodatabase replica type.
Having a combination of versioning registration types is not supported when creating a geodatabase replica:
  • Two-way replicas require data to be registered for traditional versioning.
  • One-way replicas require the source data to be registered for traditional versioning. The target data in a one-way replica can be nonversioned if you use a simple access type model.
  • Checkout replicas allow traditional versioned or nonversioned data but cannot contain a combination of both registration types. If working with nonversioned data, a combination of archive-enabled data and data without archiving enabled is not supported.
See Prepare data for replication to get started with geodatabase replication.
Dataset support
The following table lists geodatabase datasets and their compatibility with geodatabase replication in ArcGIS Pro:
Dataset
Edit using traditional versioning
Read-only
Not supported
Table
Can edit tables using traditional versioning
Feature class
Can edit feature classes using traditional versioning
Annotation
Can edit annotation feature classes using traditional versioning
Dimension
Can edit dimension feature classes using traditional versioning
Relationship class
Can edit the relationship class and datasets in it using traditional versioning
Topology
Can edit the topology and datasets in it using traditional versioning
Network dataset
Can edit a subset of feature classes in the network dataset using traditional versioning
Terrain dataset
Can edit the feature classes in the terrain dataset using traditional versioning
Mosaic dataset
Mosaic datasets are read only
Representation
Feature classes containing representations are read only
Parcel fabric
Parcel fabrics are not supported in replicas
Utility network
Utility networks are not supported in replicas
Geometric network
Geometric networks are not supported in replicas
Attribute rules
Attribute rules are not supported in replicas
Contingent values
Contingent values are not supported in replicas
Learn more about replicating datasets that participate in advanced geodatabase functionality
