COGO and Ground to Grid tools for editing
Coordinate Geometry (COGO) and ground to grid correction tools for editing are used to map the location of features and their boundaries measured on the ground and recorded in physical or electronic land record documents.
The editing tools listed in the following tables include additional functionality for editing COGO-enabled features and creating geometry based on the current ground to grid correction settings. You can use them with standard geodatabase features and features contained in parcel fabrics.
Feature construction tools
The tools in the following table are available when you are actively drawing a feature using a feature construction tool in the Create Features pane.
Tool
Ground to grid distance factor
Ground to grid direction offset
Circular Arc .
Create two-point tangent or non-tangent circular arc segments based on specified parameters.
Verified
Verified
Spiral Curve Spiral curve constraint
Create clothoid spiral curves based on specified parameters.
Verified
Verified
Intersection tools
Solve basic analytic geometry problems to place a point feature or a vertex, such as finding the intersection of two radial distances or of two directions.
Verified
Verified
Direction Direction
Constrain the current segment to the specified direction value.
Verified
Distance Distance
Constrain the current segment to the specified distance.
Verified
Direction/Distance Direction-Distance
Create a vertex at the specified horizontal direction and distance measured from the last vertex.
Verified
Verified
On-screen Constraints
Specify direction and distance using on-screen text box controls.
Verified
Verified
Feature modification tools
The tools in the following table are available in the Modify Features pane.
Tool
Traverse Traverse
Create a series of line features or a single polygon feature by typing values.
This tool supports single-handed data entry using the numeric keypad.
Verified
Verified
Update COGO Update Attributes
Update the direction and distance attributes of a COGO-enabled line feature to match the selected feature geometry.
If ground to grid is turned on, the calculated values are rotated and scaled by the current correction settings.
Verified
Verified
Cul-de-sac Cul-de-sac
Create cul-de-sac geometry that is aligned with a selected line feature representing the centerline of a road.
Verified
Verified
Split lines into COGO lines Split Into COGO Lines
Create two-point COGO lines and arcs from selected line features. The feature is split at each vertex.
Verified
Verified
Extend or Trim Extend or Trim
Extend or trim a line feature to an existing feature boundary.
Check the Recalculate COGO attributes check box in the tool pane to recalculate existing COGO attributes values.
Fillet Fillet
Create a tangent circular arc between two segments by reshaping the first segment and trimming the second segment.
Verified
Line Intersection Split at Intersection
Split straight and curved line features at intersections or inferred intersections. You can extend a line to an inferred intersection or create a segment.
Split Split
Split editable and visible features into two or more features. You can draw a line to create the split or select input cutting features and split only selected target features.
Verified
Divide Divide
Divide a single-part polyline feature into multiple features that have equal or varying distances or a percentage of the total length.
Verified
The distance factor is applied only if the Length or Arclength fields do not contain values and the tool is not set to distribute the remaining length equally or proportionally.
Copy Parallel Copy Parallel
Copy line features parallel or concentric to existing line features at a specified offset distance.
Verified
Offset Offset
Create features at specified distances along a line at a specified perpendicular offset from the line.
Verified
Merge Merge
Combine two or more features on the same layer that share coincident vertices into one feature. You can replace the existing feature, or keep it and create a feature.
Existing COGO attribute values are automatically recalculated.
Planarize Planarize
Split overlapping features on the same layer into individual segments at each intersection and delete coincident line segments.
Existing COGO attribute values are automatically recalculated. Null COGO attribute values remain as null values on the split lines.
Change Line Length
Change the total length of one or more selected line features to a specified length or by a specified value.
Entered values for COGO lines are scaled using ground to grid correction settings for the active map. Alternatively, you can set this tool to proportionately scale COGO line geometry using the COGO Distance (lines) or Arclength (circular arcs) field values.
Verified
Measurement tools
The tools in the following table are available on the ribbon on the Map tab.
Tool
Measure Direction Distance Measure Direction and Distance
Draw a line on the map to measure the straight-line direction and distance between two or more points.
Verified
Verified
Measure Offset Measure Offset
Measure one or more perpendicular offset distances from a baseline you draw.
Verified
