ArcGIS.Core.CIM Namespace / CIMSingleFillScaleBar Class
Properties Methods Events
    CIMSingleFillScaleBar Class Members
    The following tables list the members exposed by CIMSingleFillScaleBar.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the scale bar should align to zero. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the anchor position of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the scale bar height. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the width of the scale bar. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether to compute the scale at map center. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the custom properties of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether to display the first numeric value outside the bar. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether to display the last numeric value outside the bar. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the division value. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the division mark height value. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the division mark line symbol. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the number of divisions. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the number of divisions before zero. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether this element is expanded in the contents pane. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the fill symbol for the scale bar.
    Public Property Gets or sets the fitting strategy. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the geometry of a frame for an element. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the graphic symbology of an element's frame. (Inherited from ArcGIS.Core.CIM.CIMFrameElement)
    Public Property Gets or sets the label frequency. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the label gap value. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the label position. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets label symbol. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether the element is locked. Each element in the contents pane has a lock icon. If the icon is shown as locked, you can not select that feature in the layout using the select tool. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets a value indicating whether the aspect ratio for an element is locked. If locked, the width and height values stretch proportionally. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the map frame associated with the map surround. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the division mark frequency. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the division mark position. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the maximum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the midpoint mark height. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the midpoint mark line symbol. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the minimum scale. (Inherited from ArcGIS.Core.CIM.CIMMapSurround)
    Public Property Gets or sets the name of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the number format. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the rotation of the element. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the location of the anchor in page units.This is also the location the feature is rotated around. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the subdivision mark height. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the subdivision mark line symbol. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the number of subdivisions. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the unit label. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the unit label gap. Units set in points. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the unit label position. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the unit label symbol. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets the units for the scale bar. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether fractional characters should be used. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Public Property Gets or sets a value indicating whether the element is visible. (Inherited from ArcGIS.Core.CIM.CIMElement)
    Public Property Gets or sets the zero location for the scale bar. (Inherited from ArcGIS.Core.CIM.CIMScaleBar)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMSingleFillScaleBar.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMSingleFillScaleBar with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMSingleFillScaleBar and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
