Surface geoprocessing functions
Disponible con licencia de Spatial Analyst.
Disponible con licencia de Analista 3D.
With the Surface geoprocessing functions, you can quantify and visualize a terrain landform represented by a digital elevation model.
Starting with a raster elevation surface as input, with these geoprocessing functions, you can gain information by producing a new dataset that identifies a specific pattern within an original dataset. You can derive patterns that were not readily apparent in the original surface, such as contours, angle of slope, steepest downslope direction (Aspect), shaded relief (Hillshade), and visibility.
Each Surface geoprocessing function provides insights into a surface that can be used as an end in itself or as input into additional analysis.
The following table lists the available geoprocessing functions and provides a brief description of each.
Geoprocessing function
Add Surface Information
Attributes features with spatial information derived from a surface.
Aspect
Derives the aspect from each cell of a raster surface.
Contour
Creates a feature class of contours from a raster surface.
Contour List
Creates a feature class of selected contour values from a raster surface.
Contour with Barriers
Creates contours from a raster surface. The inclusion of barrier features allows you to independently generate contours on either side of a barrier.
Curvature
Calculates the curvature of a raster surface and, optionally, includes profile and plan curvature.
Cut Fill
Calculates the volume change between two surfaces. This is typically used for cut and fill operations.
Feature Preserving Smoothing
Smooths a surface raster by removing noise while preserving features.
Geodesic Viewshed
Determines the raster surface locations visible to a set of observer features using geodesic methods.
Geomorphon Landforms
Calculates the geomorphon pattern of each cell of an input surface raster and classifies calculated geomorphons into common landform types.
Hillshade
Creates a shaded relief from a surface raster by considering the illumination source angle and shadows.
Interpolate Shape
Creates 3D features by interpolating z-values from a surface.
Multiscale Surface Deviation
Calculates the maximum deviation from the mean value across a range of spatial scales.
Multiscale Surface Difference
Calculates the maximum difference from the mean elevation across a range of spatial scales.
Multiscale Surface Percentile
Calculates the most extreme percentile across a range of spatial scales.
Observer Points
Identifies which observer points are visible from each raster surface location.
Slope
Identifies the slope (gradient or steepness) from each cell of a raster.
Surface Area Ratio
Calculates a surface area to planar area ratio for each cell of a raster surface.
Surface Parameters
Determines parameters of a raster surface such as aspect, slope, and curvatures.
Top Hat Transform
Detects spatial structures on a raster surface by calculating the top hat transforms.
Topographic Position Index
Calculates the topographic position index value for each cell within a specified neighborhood.
Viewshed
Determines the raster surface locations visible to a set of observer features.
Visibility
Determines the raster surface locations visible to a set of observer features, or identifies which observer points are visible from each raster surface location.
Geoprocessing functions in the Surface category
