Application settings available for administrator control
The topics in this section provide more information on the settings that you can include in the Pro.settingsConfig file. This includes the functional area; the corresponding setting in the user interface; possible values, including the default value; and an example.
The sections below correspond to an element in the Pro.settingsConfig file and contain the individual settings available in each one.
Animation settings
The following settings are under the Animation element of the Pro.settingsConfig file:
The following settings are under the Application element of the Pro.settingsConfig file:
Authentication settings
The following setting is under the Authentication element of the Pro.settingsConfig file:
Catalog settings
The following settings are under the Catalog element of the Pro.settingsConfig file:
Color Management settings
The following settings are under the ColorManagement element of the Pro.settingsConfig file:
Display settings
The following settings are under the Display element of the Pro.settingsConfig file:
Editing settings
The following settings are under the Editing element of the Pro.settingsConfig file:
Geodatabase Replication settings
The following settings are under the GeodatabaseReplication element of the Pro.settingsConfig file:
Geoprocessing settings
The following settings are under the Geoprocessing element of the Pro.settingsConfig file:
Layout settings
The following setting is under the Layout element of the Pro.settingsConfig file:
Map and Scene settings
The following settings are under the MapAndScene element of the Pro.settingsConfig file:
Navigation settings
The following settings are under the Navigation element of the Pro.settingsConfig file:
Network Analyst settings
The following setting is under the NetworkAnalyst element of the Pro.settingsConfig file:
Oriented Imagery settings
The following setting is under the OrientedImagery element of the Pro.settingsConfig file:
Portal settings
The following settings are under the Portals element of the Pro.settingsConfig file:
Project settings
The following settings are under the Projects element of the Pro.settingsConfig file:
Local and portal project settings
Local project settings
Portal project settings
Report settings
The following setting is under the Report element of the Pro.settingsConfig file:
Selection settings
The following settings are under the Selection element of the Pro.settingsConfig file:
Share and Download settings
The following settings are under the ShareDownload element of the Pro.settingsConfig file:
Table settings
The following settings are under the Table element of the Pro.settingsConfig file:
Text and Graphics settings
The following settings are under the TextAndGraphics element of the Pro.settingsConfig file:
Versioning settings
The following settings are under the Versioning element of the Pro.settingsConfig file:
