Visualize temporal data
Geographic data often has an important temporal component. Temporal data—information about features and attributes at different points in time—can help you explore phenomena as diverse as crime trends, the spread of an invasive species, and traffic accident patterns.
Overview
  • This video was created with ArcGIS Pro 3.6.
In this tutorial, you'll visualize changes in international tourism in New Zealand over the past 20 years—changes that have major business implications for the country. Optionally, you'll export your visualization as a video file that can be shared to social media platforms.
  • Estimated time: 50 minutes, 70 minutes with optional section
  • Software requirement: ArcGIS Pro Basic
The quick-start tutorials are updated at each software release. For the best experience, use an online help version that matches your software version.
Open the project
Tourism is an important part of New Zealand's economy. For the fiscal year that ended in March 2020, tourism made up 5.5 percent of the country's gross domestic product (GDP) and is a major employer. Knowing where tourists come from, which parts of New Zealand they visit, and how long they stay helps planners choose the right locations for hotels, tour companies, and other services.
Using data from New Zealand's International Visitor Survey, you'll visualize increases in the Chinese tourism market in New Zealand over a 21-year period prior to the COVID-19 pandemic. Although the upward trend began to reverse itself in 2019, China remains New Zealand's second-largest tourist market, after Australia.
  1. Start ArcGIS Pro and sign in if necessary.
  2. Open a browse dialog box to search for the project in one of the following ways:
    • On the start page, click Open another project .
    • In an open project, click the Project tab on the ribbon. In the list of side tabs, click Open. On the Open page, click Open another project .
      Open another project command
  3. On the Open Project browse dialog box, in the navigation pane, under Portal , click ArcGIS Online .
    If you are signed in to ArcGIS Enterprise , you must set your active portal to ArcGIS Online to access the tutorial data. If you can't do this, you can download the data from a browser.
  4. At the top of the dialog box, in the Search box, type Visualize temporal data and press the Enter key.
  5. In the list of search results, click Visualize temporal data to select the project package.
    Open Project dialog box showing selected project package
    If there is more than one project package with this name, select the package with the Authoritative badge . In the Owner column, the owner name is ArcGISProTutorials. If you don't get any results, see No search results are returned.
  6. Click OK.
    The project opens with a map showing New Zealand's territorial authority boundaries and a few cities. Territorial authorities are the second tier of local government in New Zealand, below regional councils.
    Map of New Zealand territorial authorities and cities
  7. On the ribbon, click the View tab. In the Windows group, click Pane Sets and click Geoprocessing .
    This ensures that the Contents, Catalog, and Geoprocessing panes are open and that other panes are closed.
  8. In the Contents pane, right-click the Cities layer and click Attribute Table .
    The table contains records for 10 cities. Because of a display filter on the layer, only five features are displayed and labeled on the map.
  9. In the Contents pane, right-click the Territorial Authorities layer and click Attribute Table .
    The table contains 68 records. There are 67 territorial authorities and one record for areas outside a territorial authority. There are no attributes with information on tourism; that data is contained in a separate file you'll add to the project.
  10. Close the open attribute tables.
Add an Excel worksheet to the project
The Chinese tourism data is found in an Excel file included in the project package. You'll add a worksheet from the file to your project.
  1. On the ribbon, click the Map tab. In the Layer group, click Add Data .
  2. On the browse dialog box, in the navigation pane, under Project , click Folders to show folders associated with the project.
  3. In the file list, browse to Visualize Temporal Data > commondata > userdata. Double-click ChineseVisitorsByTA.xlsx and click the 'Percent Chinese Tourism by TA$' worksheet to select it.
    Add Data browse dialog box with Excel sheet selected
  4. Click OK.
    The Excel sheet is added as a table to ArcGIS Pro and appears in the Contents pane.
  5. In the Contents pane, under Standalone Tables, right-click 'Percent Chinese Tourism by TA$' and click Open .
    Stand-alone table created from Excel sheet.
    Each column in the table lists a different territorial authority. Each row lists a year from 1997 to 2017. Cell values represent tourists from China as a percentage of all international tourists. Null values indicate missing or insufficient data—they do not indicate values of zero.
    This work is based on/includes Stats NZ’s data, which are licensed by Stats NZ for reuse under the Creative Commons Attribution 4.0 International license.
  6. On the Quick Access Toolbar, click Save Project .
Transpose table fields
In the 'Percent Chinese Tourism by TA$' table, the temporal units (years) are rows and the geographic units (territorial authorities) are columns. In another table, you might find that the rows are geographic units and the columns are temporal units. To visualize temporal change on a map, you must store each unique combination of place and time as a table row with the spatial and temporal values in separate columns.
This table has 21 rows for years and 64 columns for territorial authorities. (A few are missing.) You need to create a table that stores a row for each of the 1,344 (21 x 64) unique combinations of year and territory. You'll use the Transpose Fields tool to put the data into this format.
  1. Make the Geoprocessing pane active. In the search box, type Transpose Fields.
    As you type, search results are returned. The first result should be the Transpose Fields tool.
  2. In the list of search results, click Transpose Fields to open the tool.
  3. For Input Table, click the drop-down arrow and click 'Percent Chinese Tourism by TA$'.
  4. Under Fields To Transpose, next to Field, click Add Many .
  5. Next to the search box, check the Toggle All Checkboxes check box to select all the fields. At the top of the list, uncheck the Year check box.
    Transpose Fields tool with fields to transpose specified
  6. Click Add.
    These fields will become rows in the output table.
  7. Scroll to the bottom of the Geoprocessing pane. For Output Table, delete the entire path and type ChineseTourismTransposed.
    The path to your default geodatabase will be restored automatically.
  8. For Transposed Field, type TerritorialAuthority.
  9. For Value Field, type ChinesePercentageOfTotal.
    The transposed field is a new field in the output table that will store the names of the territorial authorities. The value field is a new field that will store the Chinese tourism percentage values. You can use any names you like for these fields.
  10. Under Attribute Fields, click the input box drop-down arrow (not the Add Many button Add Many) and click Year.
    Transpose Fields tool with all parameters specified
  11. Click Run .
    When the tool finishes, a new table is added to the Contents pane. You'll confirm that the table has been saved to your default geodatabase.
  12. Make the Catalog pane active. Expand Databases and expand visualize_temporal_data.gdb.
    Contents of default geodatabase
    The default geodatabase contains three items: the table you created and two feature classes that are the data sources of layers in the map.
    Tip:
    If you don't see the table, right-click the default geodatabase and click Refresh .
  13. Close the 'Percent Chinese Tourism by TA$' table.
  14. In the Contents pane, under Standalone Tables, right-click ChineseTourismTransposed and click Open .
  15. Scroll through the table.
    Transposed table
    The table has what you need: a separate row for each unique combination of year and territory. However, not all the fields have the correct data type.
  16. Hover over the ChinesePercentageOfTotal field heading.
    Pop-up showing properties of the field.
    The field values represent percentages, but the field data type is Text. You need a numeric field that displays decimal points. Since you can't change the data type of a field, you'll add a new field and populate it with the same values.
    When an Excel table is processed in ArcGIS Pro, fields that contain values of mixed data type—including a combination of numbers and null values—are output as text fields. Learn more about using Microsoft Excel files in ArcGIS Pro.
  17. Hover over the Year field heading.
    The data type for this field is Double, a numeric type that supports numbers with high-precision decimal values. Although you can display temporal data when the time values are stored as numbers (or text, for that matter), the best practice is to store them in a date field. You'll convert the year values to dates.
    Learn more about ArcGIS field data types
Add a field and calculate its values
You'll add a numeric field to the table and calculate the tourism percentage values, currently stored as text, into the new field.
  1. In the Contents pane, click the ChineseTourismTransposed table to select it, if necessary.
  2. On the ribbon, click the Standalone Table tab.
  3. In the Data Design group, click Fields .
    The fields view of the table opens. You use the fields view to work with field properties. In the fields view, each field in the ChineseTourismTransposed table is presented as a row, and each field property is presented as a column. On the ribbon, the Fields tab appears and is active.
  4. On the ribbon, on the Fields tab, in the Edits group, click New .
    The new field is added as the last row in the fields view of the table. In the Field Name column, the default name Field is selected.
  5. Click in the selected cell to make it editable. Change the field name to ChinesePercentage and press the Enter key.
  6. In the same row, in the Data Type column, double-click the default value Long. In the drop-down list of data types, click Float.
    Fields view of the transposed table with a field added
    Like Double, the Float data type supports decimal places, but uses less storage space.
  7. On the ribbon, on the Fields tab, in the Manage Edits group, click Save to save your table schema changes.
  8. Close the Fields: ChineseTourismTransposed view.
    The new field displays in the ChineseTourismTransposed table with <Null> values. Now you'll calculate values for the field.
    Tip:
    If you don't see the new field in the table, click Refresh at the bottom of the table view.
  9. In the table, click the column heading of the ChinesePercentage field and click Calculate on the toolbar at the top of the table.
    Tip:
    If you have configured ArcGIS Pro to enable and disable editing, the Calculate command will be disabled. Click the Edit tab on the ribbon and click Enable editing .
    The Calculate Field toolbar appears just below the toolbar on the table.
    The Calculate Field toolbar with the target field and expression boxes identified
    On the Calculate Field toolbar, the ChinesPercentage field appears as the target field because it is selected in the table.
  10. In the expression box, click Add Fields to Expression . In the pop-up window, click ChinesePercentageOfTotal.
    The Calculate Field toolbar showing the expression to be calculated
    The full expression is ChinesePercentage = !ChinesePercentageOfTotal!. (The exclamation points are Python syntax.) When you calculate the expression, the target ChinesePercentage field will get the values from the ChinesePercentageOfTotal field, but they will be stored as numbers instead of text.
  11. Click Calculate on the Calculate Field toolbar.
    The ChinesePercentage field is populated with numeric values expressed to six decimal places.
  12. On the ribbon, click the Edit tab. In the Manage Edits group, click Save .
  13. On the Save Edits prompt, click Yes.
  14. Click the column heading of the ChinesePercentageOfTotal field (the text field) to select the field. Right-click the column heading and click Delete .
    Delete Field prompt
  15. On the Delete Field prompt, confirm that you are deleting the correct field (ChinesePercentageOfTotal). Click Yes.
  16. On the Quick Access Toolbar, click Save Project .
Convert time values to date format
It's a good practice to store time values in date fields. Although it's not necessary for this tutorial, some advanced analysis operations require it.
  1. Make the Geoprocessing pane active and click Back .
  2. In the search box, type Convert Temporal Field.
    The Convert Temporal Field tool should be the first search result.
  3. Click Convert Temporal Field to open the tool.
  4. Set the Input Table parameter to ChineseTourismTransposed.
  5. Set the Input Field parameter to Year.
  6. On the Input Format parameter, click Set Format . Click the Date Format drop-down arrow and click yyyy. Ignore the Locale setting and click outside the drop-down list.
  7. Under Output Field Name, accept the default name Year_Converted. Confirm that the Output Field Type parameter is set to Date.
    Convert Time Field tool
  8. Click Run .
    The new Year_Converted field is added to the table and populated with dates.
    Table showing new fields.
  9. Click the column heading of the Year field (not the Year_Converted field) to select the field. Right-click the column heading and click Delete.
  10. On the Delete Field prompt, confirm that you are deleting the correct field (Year). Click Yes.
  11. On the Quick Access Toolbar, click Save Project .
Join the table to the layer
To display the data by time on the map, you need to join the ChineseTourismTransposed stand-alone table to the Territorial Authorities layer in the map. A join temporarily connects tables so that attributes from one table (usually a stand-alone table) can be queried or symbolized as if they belonged to another table (usually a layer attribute table).
A join requires that the two tables have a common attribute. In this case, both the Territorial Authorities layer attribute table and the ChineseTourismTransposed table have a field containing the names of territories.
There are 68 records in the Territorial Authorities table (the input table) and each territory name occurs once. There are 1,344 records in the ChineseTourismTransposed table (the join table) and each territory name occurs 21 times. Because one record in the input table will match multiple records in the join table—all records with the same territory name will match—the join is a one-to-many join.
One-to-many joins can only be performed when the input and join tables are in the same workspace (such as the same file geodatabase) and both have Object ID fields.
  1. In the Contents pane, right-click the Territorial Authorities layer and click Attribute Table .
    Notice that the values in the Name field are formatted with underscores between words.
  2. Make the ChineseTourismTransposed table active. (If necessary, open the table.)
    Names in the TerritorialAuthority field are also formatted with underscores between words. It's not necessary that the common field have the same name in both tables. However, it is necessary that the field values be formatted the same way.
  3. Close the ChineseTourismTransposed table.
  4. In the Contents pane, right-click the Territorial Authorities layer, point to Joins and Relates, and click Add Join .
    The Add Join tool appears in a floating window.
  5. Set the Add Join tool parameters as follows:
    • For Input Table, accept Territorial Authorities.
    • For Input Field, choose Name.
    • For Join Table, choose ChineseTourismTransposed.
    • For Join Field, accept TerritorialAuthority (or choose it, if necessary).
  6. Check the Index join fields check box.
    Add Join parameters
  7. Click Validate Join.
    When you validate a join, potential problems are analyzed, and information about the join is presented in a message box. In this case, there are no problems.
  8. Click Close on the Validate Join message.
  9. Click OK on the Add Join tool.
    When the tool finishes running, the attributes from the ChineseTourismTransposed table are appended to the table.
    The table has 1,348 total records, of which 1,344 are matched. Four of the original 68 records in the Territorial Authorities attribute table don't have matching records in the ChineseTourismTransposed table. (Recall that only 64 territorial authorities were represented in the Excel worksheet.) For the four unmatched records, null values are assigned to the joined fields.
  10. Scroll across the table.
    You can hide attributes that you don't need.
  11. In the attribute table, right-click any column heading and click Fields to open the fields view of the table.
  12. In the Visible column of the fields view, uncheck the check box in the column heading to turn off the visibility of all fields in the table.
  13. Check the Visible check boxes next to the following fields to make them visible:
    • TA_name (with the alias Name)
    • ChineseTourismTransposed.ChinesePercentage (with the alias ChinesePercentage)
    • ChineseTourismTransposed.Year_Converted (with the alias Year_Converted)
    The prefix ChineseTourismTransposed indicates that these fields come from the join table. The join applies only to the map layer, not to its source data. You can make a join permanent by exporting the layer to a new feature class.
  14. On the ribbon, on the Fields tab, in the Manage Edits group, click Save .
  15. Close the Fields: Territorial Authorities view.
    The Territorial Authorities table now displays three fields: Name, ChinesePercentage, and Year_Converted.
    Tip:
    If necessary, click Refresh at the bottom of the table view to see the changes.
  16. Close the table.
  17. On the Quick Access Toolbar, click Save Project .
Visualize trends with a line chart
You'll create a line chart to examine the Chinese tourism trend over time. There are too many territorial authorities to show in a single chart, so you'll focus on those that contain features in the Cities layer. To select these territories, you'll use the Select By Location tool.
  1. On the ribbon, click the Map tab if necessary. In the Selection group, click Select By Location .
    The Select By Location tool appears in a floating window.
  2. Confirm that the Input Features parameter is set to Territorial Authorities.
  3. Click the Relationship drop-down arrow and click Contains.
  4. Click the Selecting Features drop-down arrow and click Cities.
    Select By Location window
    When the tool runs, territorial authorities that contain cities are selected. Recall that there are 10 features in the Cities layer—five are filtered out by a display query. Features filtered out by a display query can still be used for selection and analysis, unlike features hidden by a definition query.
  5. Click OK.
    On the map, 10 territorial authorities are selected. The number of selected features is confirmed in the status bar at the bottom of the map view.
  6. In the Contents pane, right-click the Territorial Authorities layer, point to Create Chart , and click Line Chart .
    The Chart Properties pane and an empty chart view appear. Before configuring the chart, you'll apply a selection filter so the chart displays only features selected on the map.
  7. In the row of tools at the top of the empty chart view, click Filter By Selection .
    The Filter By Selection button is outlined to indicate that it is selected.
  8. In the Chart Properties pane, on the Data tab, click the Date or Number drop-down arrow and click Year_Converted.
    On the chart, the years appear on the x-axis.
  9. In the Chart Properties pane, under Numeric field(s), click Select. In the selection window, check the ChinesePercentage check box and click Apply.
    Values for the percentage of Chinese tourists appear on the y-axis; however, the values are summed for the selected territorial authorities, which doesn't make sense in this context.
  10. In the Chart Properties pane, click the Split by (optional) drop-down arrow and choose Name.
  11. Click Yes on the Chart properties warning message.
    Because you placed a selection filter on the chart, only 10 territories are displayed.
  12. In the Chart Properties pane, under Time binning options, under Interval size, click Determine interval size for time aggregation and change the Years value to 1.
  13. Uncheck the Trim incomplete interval check box.
    This ensures that the last year of data is included in the chart. Learn more about time binning options in line charts.
    Default chart display and time binning settings in Chart Properties pane
    On the chart, a line is drawn for each of the 10 selected territorial authorities. By default, the color of each line matches the feature's symbol color in the Territorial Authorities layer.
    Tip:
    To see the chart better, you can float the chart view and resize it. To float the view, right-click its view tab and click Float, or drag the view tab away from the docked position.
Modify chart properties
To improve the chart's appearance, you'll change the title and axis labels, choose different line colors, and edit the legend labels.
  1. In the Chart Properties pane, click the General tab.
    Tip:
    If your pane is narrow, you may not see all the tabs. You can widen the pane or click More and choose the tab you want from a drop-down list.
  2. Under Chart title, change the title to Chinese Percentage of International Tourism in New Zealand. Press the Enter key.
    The chart title is updated.
  3. Under X axis title, change the text to Year and press the Enter key.
  4. Under Y axis title, change the text to Percentage and press the Enter key.
  5. In the Chart Properties pane, click the Series tab.
    A table displays the territorial authorities by their names, symbols, and labels. To make the line symbols stand out from each other, you'll apply a color scheme.
    Table of values, symbols, and labels on the Series tab of the Chart Properties pane
  6. Click the Color scheme drop-down arrow and click the first color scheme in the list.
    The symbols update on the chart and in the Chart Properties pane. (The name of this color scheme is Basic Random. You can hover over the color scheme to see its name as a ScreenTip.)
    Chart with updated symbols
    A quick glance shows that the trend for most of the territories is upward. The trend starts earlier and goes higher for Rotorua District than for the other territories.
  7. In the chart legend, click the name of any territory.
    The name dims in the legend and its line disappears from the chart. This allows you to compare a few values at a time.
  8. Click the territory you dimmed to display it again.
  9. Dim the following territories:
    • Christchurch City
    • Dunedin City
    • Invercargill City
    • Nelson City
    • Queenstown-Lakes District
    The territories that are still displayed are on the North Island. The five that you dimmed are on the South Island.
  10. Hover over any data point on a line.
    ScreenTip showing percentage value for Rotorua District territorial authority in 2012.
    You see the name of the territorial authority, the year represented, and the percentage of Chinese tourism for that year. For example, Chinese tourism in Rotorua District peaked in 2012, when nearly a quarter of international tourists came from China.
  11. Optionally, continue to work with the chart. Try the following suggestions or experiment on your own.
    • Turn off the lines for the North Island territories and turn on the lines for the South Island territories. The values tend to peak later—perhaps suggesting that the South Island became a destination for tourists who had previously visited the North Island.
    • Click the Display multiple series as drop-down list in the Chart Properties pane and click Grid. This displays each of the ten selected territories as a separate chart and arranges them in a grid for comparison.
    • Update the chart with interactive selections on the map. On the ribbon, click the Map tab. In the Selection group, click the Select tool . Hold the Shift key and click a territory on the map to add it to the selection set. Hold the Ctrl key and click a selected territory to deselect it.
    • Use Filter By Extent on the chart view—either by itself or in combination with Filter By Selection . When Filter By Extent is selected, only features visible in the map extent are shown on the chart.
  12. When you're finished, close the chart view and the Chart Properties pane.
    Two other chart types—data clock and calendar heat chart—are specifically designed for representing temporal data. These chart types are useful for temporal data that is measured in fine increments such as months, weeks, or days.
  13. On the ribbon, click the Map tab, if necessary. In the Selection group, click Clear to deselect the selected features.
    The chart is saved with the Territorial Authorities layer and can be reopened from the Contents pane of the map. However, because this chart was created from a layer selection, it does not display its data after you clear the selection. The settings in the Chart Properties pane are saved, and you can restore the chart's appearance by recreating the layer selection.
  14. On the Quick Access Toolbar, click Save Project .
Symbolize the territorial authorities
On the map, the territories are symbolized by unique values. You'll switch to a graduated color scheme and use lighter and darker hues to represent lower and higher percentages of Chinese tourists.
  1. In the Contents pane, right-click the Territorial Authorities layer and click Symbology .
    The Symbology pane appears.
  2. Under Primary symbology, click the drop-down arrow and click Graduated Colors.
    The field to symbolize is automatically set to ChinesePercentage (the only available numeric field). A default color scheme is applied and the data is grouped into five classes.
    You'll apply a yellow to red color scheme and keep the same number of classes.
  3. Click the Color scheme drop-down arrow. Under the scrolling list of color schemes, click More color schemes.
  4. In the Choose a color scheme dialog box, click in the search box and type yellow orange red 5. Press the Enter key.
    Choose a color scheme dialog box with search results
    A few color schemes are returned by your search.
  5. Under ColorBrewer Schemes (RGB), click the Yellow-Orange-Red (5 Classes) scheme and click OK.
    The color scheme updates in the Symbology pane and on the map.
    In the lower part of the Symbology pane, on the Classes tab, the class breaks reflect value clusters in the data (natural breaks), but they are not intuitive to a map reader. You'll change the class break values and labels.
  6. On the Classes tab, click the More drop-down arrow and click Always update class labels to uncheck it.
    Unchecking this setting prevents the class labels from updating when the upper values are changed.
  7. Edit the Upper value and Label columns as shown in the table below. Double-click a cell to make it editable and press the Enter key to commit an edit.
    Symbol Upper value Label
    Yellow symbol 2 Less than 2%
    Light orange symbol 5 2% - 5%
    Medium orange symbol 10 5% - 10%
    Dark orange symbol 20 10% - 20%
    Red symbol 32.457027 (Leave the default value unchanged.) More than 20%
  8. Click the More drop-down arrow and click Show values out of range.
    A gray symbol is added below the other symbols. This symbol represents null values in your data—territories that have no information for a particular year.
  9. Right-click the gray <out of range> symbol to open the color palette. Click Gray 20%.
    Color palette with Gray 20% indicated (row 3, column 1).
  10. Change the label for the out of range data to No Data.
    Symbology pane settings
    On the map, the Territorial Authorities layer reflects the new color scheme. The colors look faint because transparency was applied to the original symbology.
  11. In the Contents pane, ensure the Territorial Authorities layer is selected. On the ribbon, click the Feature Layer tab. In the Effects group, in the Transparency box , replace the current value with 0 and press the Enter key.
  12. In the Contents pane, turn off the Cities layer. Expand the Territorial Authorities layer to see its legend.
    Contents pane and map with graduated color symbology
    At the moment, only one value is symbolized for each feature on the map. To see the data change year by year, you'll enable time on the layer.
  13. On the Quick Access Toolbar, click Save Project .
Enable time and visualize the data
You can display temporal data with a time slider that is similar to a video player. A Time contextual tab on the ribbon provides more settings for displaying the data. The time slider and ribbon tab become available when you enable a layer's time property.
  1. In the Contents pane, right-click the Territorial Authorities layer and click Properties .
  2. On the Layer Properties dialog box, in the list of side tabs, click Time.
  3. Under Filter using time, click Filter layer content based on attribute values.
    Additional settings display under the selected option. The default values for these settings are correct.
    Layer Properties dialog box with time settings
  4. Click OK.
    The time slider appears at the top of the map view.
  5. Hover over the time slider to see its controls.
    Disabled time slider
  6. On the left side of the time slider, click Time disabled to change it to Time enabled .
    Time-enabled layer on map
    The time span collapses to the first value in the range, and the map displays the data for 1997. In that year, Chinese tourists did not make up more than 2 percent of international visitors to any territory. Most of the territories have no data for that year.
    You'll configure the time slider to play back the data in one-year intervals.
  7. On the ribbon, click the Time tab. In the Snapping group, check the Time Snapping check box.
  8. Under the check box, click the Define Full Extent drop-down arrow and click Years.
    This setting corresponds to the yearly intervals of the data.
  9. In the Current Time group, change the Span value to 0 and press the Enter key.
    Time settings on ribbon
    If the span value is 1, the time slider displays each year as a range. For example, you'll see ranges such as 1997–1998 and 1998–1999. When the span value is 0, each year displays as a single value. You'll see 1997, 1998, and so on. Learn more about configuring the time slider.
  10. In the Playback group, move the Adjust Playback Speed slider to the middle.
  11. In the Playback group, click Play All Steps .
    The map plays through the data, displaying the percentage of Chinese tourists visiting each territorial authority in each year. In the final years, there is a noticeable increase, especially on the South Island.
    Tip:
    You can also play the data by clicking Play All Steps on the time slider.
  12. On the Quick Access Toolbar, click Save Project .
Create an animation and export a video (optional)
In this section, you'll create an animation of the playback and export it as a video file. This allows you to share your work with others, such as business owners and stakeholders in the tourism industry, who may not have access to ArcGIS Pro.
Animations are composed of keyframes and the transitions between them. Now that you have configured time properties for the Territorial Authorities layer, you can import the time slider steps (one step per year) to the animation. Each time step becomes a keyframe.
  1. On the ribbon, click the View tab. In the Animation group, click Add .
    An empty Animation Timeline pane appears under the map view. On the ribbon, the Animation tab appears.
    Before you create keyframes for the animation, you'll zoom to the correct map extent.
  2. In the Contents pane, right-click the Territorial Authorities layer and click Zoom To Layer .
  3. On the ribbon, confirm that the Animation tab is selected (it has a blue underline). In the Create group, click Import and click Time Slider Steps .
    The Animation Timeline pane populates with 22 keyframes. It takes a few moments for the thumbnail images to display in the keyframes. The first keyframe at zero seconds (00:00.000) represents the data for 1997. Each subsequent keyframe corresponds to the data for the following year.
    Keyframes in Animation Timeline pane
    On the Animation tab, in the Playback group, the Duration setting is one minute and three seconds (01:03.000). There are 21 slide transitions, which means each slide is visible for three seconds. Since there is no camera movement (your viewpoint in relation to the map doesn't change), you don't need that much time between keyframes.
  4. On the Animation tab, in the Playback group, replace the duration value with 00:21, and press the Enter key.
    The time stamps in the Animation Timeline pane are adjusted. Each transition now takes one second.
    As the animation plays, you can show which year the data represents. You'll add dynamic text that updates during playback.
  5. In the Animation Timeline pane, under Keyframe Gallery, click the first keyframe to select it. Scroll to the end of the gallery, press the Shift key, and click the last keyframe.
    Selected keyframes
    The dynamic text you add in the next step will be applied to all the selected keyframes—in other words, throughout the animation.
  6. On the ribbon, on the Animation tab, in the Overlay group, expand the Overlay gallery.
    Overlay gallery with expander highlighted
    Depending on the size of your ArcGIS Pro window, you may see an Add Overlay button rather than gallery items. Click the button to display the gallery.
  7. In the Overlay gallery, under Dynamic Text, click Map Time .
    A box with a dynamic text expression appears as an overlay on the map view.
  8. In the dynamic text box, replace the default two-line expression with <dyn type="animation" property="startTime" format="yyyy"/>.
    Dynamic text expression
    The expression creates a single time label, rather than a start and end time, and formats it to display the year rather than a full date.
  9. On the map view overlay, click Close to commit your edits.
    You'll make the dynamic text larger and preview the animation.
  10. On the Animation tab, in the Overlay group, change the font size to 48.
    Tip:
    Options to format overlays are found on the Overlay tab of the Animation Properties pane. To open the Animation Properties pane, on the Animation tab, in the Edit group, click Properties .
  11. On the Animation tab, in the Playback group, click Play . (Don't click Play on the time slider. Changes you've made to the animation are not reflected in the time slider playback.)
    Animation keyframe during playback
    The dynamic text updates as the animation plays. You're ready to export the animation as a video file.
  12. On the Animation tab, in the Export group, click Movie .
    The Export Movie pane appears. The default settings output a video configured for YouTube in .mp4 media format.
  13. In the Export Movie pane, in the File Name box, change the default file name from New Zealand to Chinese Tourism NZ 1997 to 2017.
    Export Movie pane
    The file is saved by default to your %USERPROFILE%\Documents\ArcGIS\Media folder.
  14. Optionally, click Browse and browse to a different folder to save the video.
  15. Click Export.
    The export takes some time. You see the estimated time remaining at the bottom of the pane. When the process is finished, a Play the Video link appears in the lower left corner of the pane.
  16. Click Play the video.
In this tutorial, you visualized temporal data in various ways: as a line chart, as a dynamic map display, and—in the optional section—as an animation. Temporal data displays can draw attention to important patterns. In this case, visualizing the Chinese tourist market in time and space can help business analysts see where significant changes are occurring and where new tourism efforts should be focused.
More sophisticated temporal data analysis can be done with the tools in the Space Time Pattern Mining toolbox. For more advanced tutorials using temporal data analysis, see Investigate pollution patterns with space-time analysis and Identify popular places with spatiotemporal data science.
